Change the resistor value in the PS scheme
Old 17th February 2014, 08:18 PM   #1
erez1012 is offline erez1012
Default Change the resistor value in the PS scheme
Hi
Just want to know how much is important to use 4 of 0.47 ohm 3W in the power supply.
I have 5 resistor of 1 ohm 5W, its ok to put them??
thanks
Old 17th February 2014, 08:53 PM   #2
AudioSan is offline AudioSan  Norway
yes. that will be fine.
Old 18th February 2014, 06:14 AM   #3
the pic
Old 18th February 2014, 01:38 PM   #4
6L6 is offline 6L6  United States
6L6's Avatar
If you have (5) resistors 1.0ohm 5W, per rail, for a total of 10 in the PSU, that will work very well.
Old 19th February 2014, 06:17 PM   #5
thanks, i put 6 1.0ohm 5W for each rail.
i measure 1-3 mVOLT!! its ok?? with no load !
5 cap 10000uf for each rail
Old 19th February 2014, 06:43 PM   #6
Dennis Hui is offline Dennis Hui  Canada
With load, you should see about one sixth of
a volt drop across the resistors per amp load.
What you are seeing now seems fine.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Change the resistor value in the PS schemeHide this!Advertise here!
Please help with power conditioner scheme or accuphase ps 1210 /1220 hifi761 Power Supplies 1 27th January 2013 12:19 AM
regulated PS grounding scheme questions CharlieLaub Power Supplies 7 6th May 2011 05:24 PM
Resistor to change Qts of 12 inch driver ashok Multi-Way 0 26th May 2007 02:19 AM
About this PS Design and Ground Scheme aborza Solid State 4 2nd December 2002 01:29 AM
Leach amp R37 - R40 resistor change!? supernet Solid State 4 23rd May 2002 12:07 AM
