Old 1st March 2002, 12:47 AM   #11
PedroPO is offline PedroPO  Portugal
PedroPO's Avatar
Send a message via ICQ to PedroPO
Variac,
What heatsink do you think about using in your project?
I talked to alutronic and they say that is impossible with their extrusions (and 375x200mm) to reduce my temp to 50ºC.
Maybe I will try PR237 250x375x83mm with 9315g per channel.
share your ideas pls
Pedro Oliveira
Old 1st March 2002, 12:56 AM   #12
PassFan is offline PassFan  United States
Vince:
Most of my experience with metal has been steel, but thanks for the info.
Pedro:
You can measure your own wattage at the output on the speaker terminals. Use the formula: V squared/resistance. This will tell you but look fast at your voltmeter because its going to move like a jack rabbit. Look for peak and then average. www.borbelyaudio.com has sold heatsinks before as well as matched transistors for some of Nelsons designs. He is in Germany which should be closer to you. He is also a very nice and helpful guy. Good Luck
Old 1st March 2002, 01:36 AM   #13
grataku is offline grataku  United States
Pedro,
the point that no one seem to have addressed in the replies is that 100 deg C maybe hot for carbon based life forms like you and I but for wire wound resistor rated at 250 C is not too bad. For metal film resistors and semiconductors it's a different story. Sure it would be better if everything was operating at 40 C but lets face it, unless you want to put 100 Kg of aluminum in your livingroom that's just not gonna happen.
My advise to you is buy more heatsinks, re-distribute your components on them making sure that the mosfet don't get hotter than 50-60 C and everything will be ok.
Old 1st March 2002, 01:39 AM   #14
PedroPO's Avatar
thanks great tip! I´ll try the mosfets in another heatsink to see what happens ;-)
Old 1st March 2002, 04:29 AM   #15
Default SOZ Power Rating and Heat Sinks
I Have built a 50 watt version of SOZ. The best thing to do is to mount the mosfets on different heat sinks then the power resistors. The power resistors produce far more heat than the mosfets. If you can mount each mosfet on a separate heat sink and mount them inside your chassis using nylon screws and washer to isolate the heat sink from the chassis. Then you do not need the mica insulators. Getting rid of those mica waffers will allow far better heat transfer to your heat sink. The best insulator is no insulator. When using thermal grease. Apply the thinest layer to cover the part. Most of the diy projects I have seen have thick globs of thermal grease around the mosfet. To much thermal grease makes for poor heat transfer to you heat sink.
I would not make a 50 watt SOZ. I had a variable power supply and I found that a 15 to 20 watt version worked just as good. The speakers I used are not amp friendly. They are a large modern three way with a manufacturers stated 4 ohm impedance and 87 dB efficiency. I am sure they dropped below 4 ohms at times. This is what most speakers do. The impedance swings above and below what manufacturers claim. So, what happened when I turned the power up to 50 watts? The sound got louder. But, not by a large enough amount that I would consider worth the size and expense of going to 50 watts. I also thought at 20 watts it sounded a little better. At 50 watts the power supply, resistors and mosfets are being stressed which generates more noise. Another thing to note is even at 15 to 20 watts you think your listening to a much more powerfull amp. And I found that the low dampening factor was not a problem either. The very over built power supply I used may cause these to be less of an issue. I have been listen to tube equipment for years and I have to admit this is an amp worth building because it knows how to play music too.
Paul
Old 12th March 2002, 09:28 PM   #16
Super_BQ's Avatar
Send a message via ICQ to Super_BQ Send a message via Yahoo to Super_BQ
Arrow Funny
People and their 50 watt SoZ amps!
I just find it funny how big of a challenge for DIYers wanting a full out 50 watt / channel SoZ amp. You guys must have deep pockets for buying large heatsinks.
For my SOZ amp
http://www.geocities.com/super_bq/HiFi.html
I find that it's the mosfets that get the hottest the most. The power resistors I used don't seem to give nearly has half as much heat as the fets - but maybe it's due to where the mosfets are mounted. I found that isolating the mosfet on a separate heatsink wouldn't make much difference or a waste as it's better to utilize the aluminum chassis as a heatsink also.
My guess, the temperature i've measured off my heatsinks (where it's hottest) is no more than 40°C at room temp. I can keep my hand for several minutes so i'm quite happy with the amount of heatsinks used. I might have enough heatsinks to get squeeze 40 watts per channel but with efficient speakers.. there's really no need.
Old 13th March 2002, 05:49 PM   #17
The one and only
Nelson Pass's Avatar
Yarharhar, Smart as Paint!
Old 13th March 2002, 08:57 PM   #18
ralf is offline ralf  Germany
Lightbulb you`re right
After getting more experienced about SOZ i will build my SOZ at about 35 Watts, thats more than enough.
Each Watt above 10 Watts kosts a lot of Money.
And I wish to have my SOZ for a long time and don`t want to change MosFet`s and Resistors one time a Year.
I thank Mr. Pass for such a schematic like the Soz and the Bosoz.
I have tested it against very good leak tube Mono`s and other Amps: I can tell: it`s better. But the sound depens on the quality parts you use: the better parts the better the sound.
When my SOZ, BoSoz is finished i will test it against the best Commercial Amps.
Ralf
aleph5 temperature karajak Pass Labs 4 23rd April 2008 12:50 PM
Temperature sensors in an amp rtarbell Parts 6 30th July 2006 05:59 AM
aleph 2 temperature MikeZ Pass Labs 18 15th November 2003 02:16 AM
Page generated in 0.10629 seconds (81.58% PHP - 18.42% MySQL) with 10 queries
