Sony SITs - 2SK82 E Rank With 2SJ28 F Rank
SIT amp
A little afraid throwing this circuit into the ring to all you geniuses. Based on some Borbely front-end I once built. It has nearly 2 A of bias current. I have not tried to tweak it in Lt Spice, and most importantly, I have not built it. Thanks to M. Rothacher for 2SK82 model. (And 2SJ28, alternatively, I "inverted" the 82. I can not remember...)
Because of the high cost of these devices perhaps a cascode output stage might be worth looking at. Similar to this from Nelson's classic article. Using 2 banks of mosfets to provide the cascode shelving for the sits. Where the sits take the place of the darlington pairs of bipolars.
Well, my idea was basically to do the following:
  1. Use only JFET or VFET/SIT, not MOSFET or bipolar
  2. Complementary throughout
  3. Use a VFET/SIT follower output stage capable of handling my full range speakers (Quad ESL-63)
Of course one can discuss if this really is necessary, e.g. could the second stage be MOSFETs without any sonic degradation? But the concept is all-JFET...
Furthermore, I have not cascoded the input JFETs, but I expect I have to do something here. Because the VFETs have to be driven from something on higher voltage rails. And I am looking towards 2 x 60 W into 8 Ohms or in that vicinity.
I am also thinking along the line regulated power supplies, with pass 😎 transistors...
I cannot say cost is no object, but I strongly believe the bulk of the cost is power supplies, heat sinks and the enclosure. So there you have the background.
But thank you for the proposal of course!
