F5 v2.0 question from a novice...
Old 6th February 2014, 03:56 PM   #1
dante550 is offline dante550
Default F5 v2.0 question from a novice...
I am making good progress in my build. Power supplies up and running and tested. So I turned my attention to the F5 boards (F5 V2.0 from diyAudio Store). Started out by reviewing the excellent build guide. I managed to confuse myself about the orientation of the LED.
The instructions say the longer lead is positive and goes in the round pad. The LED in the photo is translucent so I can see that is in fact the orientation the builder put it in.
However, I thought the convention was that the longer lead (anode) goes in the square hole. The silkscreen on the board shows the anode on the right, which is the square hole. I traced the leads on the board and I think the round hole is connected to ground and V+ is connected to the square hole through R35.
Normally I would just build the board, hook it up to the power supply and see if the LED is lit, reverse it if it doesn't light and then fret if it doesn't work either way. But this is my first solid state project so I am trying to be extra careful.
Any clarification would be appreciated.
dante550
Old 6th February 2014, 04:11 PM   #2
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
The shorter lead usually marries up with the flat on the LED envelope to denote the Cathode of the device.
The symbol on the board looks like an arrow head, the point of the arrow is the Cathode.
Old 7th February 2014, 10:40 AM   #3
R.I.P.
LEDs are not good at blocking reverse current.
Inserted the wrong way can blow them.
The Bar on the schematic matches the Bar marking on the diode and the flat Bar on LED
The flat Bar is removed plastic and matches the bit of lead out that is removed to create the shorter lead out.
A translucent LED can be seen to have a Big electrode. If you equate this Big electrode (reflective cup) to the Bar you are OK
regards Andrew T.
Old 7th February 2014, 11:01 AM   #4
cviller is offline cviller  Canada
cviller's Avatar
The long lead should go to +, so if I read your description correctly, I think you are right that is should have been the square hole. The LED is not a critical part amp though, so focus on not making shorts and going slowly with the pots and you should be fine.
Old 7th February 2014, 11:09 AM   #5
R.I.P.
I can't remember little details like square pads and round pads.
I need acronyms and such to help me remember.
bbroygbvgw = ?
regards Andrew T.
Old 7th February 2014, 11:14 AM   #6
Billy Bunter Rapes Our Your Girls But Virgins Go Without - The resistor colour code.
An unethical but easily remembered anacronym.
For LEDs I remember the Kicking Cathode and that kicks a memory that that is the shorter lead.
Old 7th February 2014, 11:20 AM   #7
kasey197 is offline kasey197
The Dastardly Dad of Three
Memorable certainly tee hee
But what is that acronym supposed to remind me of exactly ?
Old 7th February 2014, 12:26 PM   #8
R.I.P.
Black Brown Red Orange Yellow Green Blue Violet Grey White
The resistor colour code from 0 to 9 for the first two or three digits.
tolerance and tempco and multiplier are different. Although Brown (1) works for tolerance of +-1%
regards Andrew T.
Old 9th February 2014, 11:16 AM   #9
fpitas is offline fpitas  United States
Here in the States, our similarly offensive mnemonic device is: Bad Boys Rape Our Young Girls, But Violet Gives Willingly. I suppose they both benefit from being memorable.
Francis
Old 14th February 2014, 01:47 AM   #10
Default thanks for all the feedback...
I have my first amp almost complete. building a pair (biamping).
sadly schedule delays completion until next week.
fingers crossed hoping for no smoke and an easy bias adjustment.
dante
F5 v2.0 question from a novice...Hide this!Advertise here!
Building an F5 Turbo v2 (in-Progress) 6L6 Pass Labs 232 20th March 2018 11:08 AM
F5 Turbo v2 and v3 soundspeed Pass Labs 6 23rd September 2013 08:59 AM
Best way to tune in BIAS F5 V2 Turbo Blink_PT Pass Labs 17 4th January 2013 10:40 AM
Looking to swap F5 Boards V1 for V2 labjr Swap Meet 0 1st March 2011 05:01 PM
DIYaudio F5 V2 mounting holes sts9fan Pass Labs 1 28th February 2011 11:04 PM
