pass x250.5 - x250.8 - diyAudio
Old 6th February 2014, 08:45 AM   #1
Default pass x250.5 - x250.8
dear nelson
are the owner of a wonderful amp x250.5
I would like to know the most important differences between my model and the new x250.8
regards Caesar
Old 6th February 2014, 03:42 PM   #2
fpitas is offline fpitas  United States
Some reading from the Pass Labs site:
https://passlabs.com/products/amplifiers/point-8
The 2014 Brochure at the bottom of the page has more information.
Francis
Old 6th February 2014, 05:37 PM   #3
The one and only
Nelson Pass's Avatar
Fundamentally, the .8 series sounds better than the .5
Of course, this is something you would want to determine for yourself.
Technically, the 250.8 has a slightly larger power supply (more capacitance),
more output stage (56 output devices vs 40), larger heat sinks, and more bias
on the front end and the output stage. There is also a larger percentage of
the output stage single-ended bias. The Class A output figure is larger.
The amplifier has a higher input impedance and lower noise. It has no
compensation capacitors in the circuitry and operates with lower feedback.
When it is turned off, the power consumption goes to less than a watt.
There are other technical innovations which we are not choosing to disclose.
Old 6th February 2014, 06:03 PM   #4
sakellogg's Avatar
i dont quite understand what you mean.
i bet if i read the serv manual it would all come together. if you email it to me ill send it right back!!
:-) :-D
I'm not crazy, my mother had me tested
Old 6th February 2014, 06:11 PM   #5
The one and only
What parts of larger and more and better are not clear?
Old 6th February 2014, 07:01 PM   #6
are this custom made sinks? or is it something one can get of the shelf?
Old 6th February 2014, 09:17 PM   #7
They're probably custom, I've never seen any exactly alike only similar.
Old 7th February 2014, 06:44 AM   #8
Thank you very much nelson for having responded to my question.
is an honor to be able to speak directly with the designer of the best amplifiers in the world.
I know many audiophiles who own amplifications pass and I'm excited.
I hope to listen to a short new series devices .8
and ... also soon be able to get hold of a pre-amp to match my x250.5 xp.20 moment
regards Caesar
Old 7th February 2014, 01:19 PM   #9
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
..yes custom Pass heatsinks from way back...very nice design as usual.
You can see the similarity with firstwatt heatsinks....same designer ? don't know but i will bet it is. :-)
C
Old 7th February 2014, 01:51 PM   #10
oh yeah
heat sinks are arranged vertically rather than horizontally as in the previous 250.5 and then, in theory, the heat dissipation is more effective
Pass X250+ Wadia martev Pass Labs 4 6th August 2009 08:44 AM
Lower the gain on a Pass X250.5? aljordan Pass Labs 10 8th January 2009 08:26 PM
pass x250.5 a little defect... kyrochan Pass Labs 10 30th May 2006 11:19 PM
Pass X250 concept ? ANALOG GUY Pass Labs 32 17th February 2006 04:08 PM
Pass X250.5 question for Nelson georgehifi Pass Labs 4 15th March 2005 07:37 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
