How can I implement the D1-Stage with an Ultra-Analog-DAC (parasound 2000)?
Old 6th January 2004, 12:28 PM   #21
Blitz is offline Blitz  Germany
In my experience the sound varies especially as well for different Idss of the different devices. So, a 389 GR sounds quite different than a BL or a V (at a given bias).
Old 6th January 2004, 12:32 PM   #22
promitheus is offline promitheus  Europe
promitheus's Avatar
Default Filter Response ?
What is the frequency response of the I/V stage from the D1?
I will be using upsampled data and want the filter to be above 48Khz.
Old 6th January 2004, 02:29 PM   #23
Klaus is offline Klaus  Germany
Default Re: Filter Response ?
Pass D1 uses 1,5k parallel to 2,7nF = 40,5kHz f_o for the 2mA PCM63. So 3V peak per branch.
I use 6,5k and 680pF = 44kHz f_o for my TDA1547 just giving 0,1mA. Just 0,65V - so 1,3V on XLR. Enough for no use of the volume adjuster of the D1.
Simply calculate your values for your DAC used.
Old 6th January 2004, 06:46 PM   #24
promitheus's Avatar
Thatīs how much I calculated last time so I wasnīt wrong.
I am planing on designing a PCB for the I/V stage. I want to replace the 4 opamps in my DAC to this.
Is anybody interested?
I want to use silver mica for the small caps.
Panasonic FC for the electrolytics.
I probably will use 4,7 uF MKP caps for the output.
Old 8th January 2004, 08:40 AM   #25
Default the schematic
Originally posted by Klaus
More to follow but for the curious guys already some pics... (sorry in another forum in German language) http://www.audiomap.de/forum/index.p...id=15097&page=
regards
Klaus
I put "my" schematic - it is more a schematic of the one and only, because I just combined P1.7 and D1 circuits – online http://www.audiomap.de/forum/index.p...id=15147&page= . Sorry, but again in German language and in another forum. I have problems to put my stuff into here (donīt know why), so I refer to the other forum which offers somewhat easier data download.
The key massage: find your own bias current! The sound is changing really radical from 3mA up to 10mA through the 2SK389. Also the DAC current will for sure change the best current value. Put one trimming resistor 150Ohm plus 63Ohm in line in for R2 and adjust the bias current. Then set R1 to U_b/2 and listen…
Test it, the sound is perfect!!!!!!!!!!!!!!!!!!!!!! Pics of my hardcore P2P work under the link in the quoted words above.
Klaus
Old 12th January 2004, 09:31 AM   #26
Default test: pic attachment
If no pic is seen I have no idea what Iīm doing wrong...
D:\Witte privat\Fotos HiFi\D1-Stufe1r.JPG
Old 12th January 2004, 09:39 AM   #27
Default it works again!
Our system admin maybe has changed again the security settings, now it works again. Nice!
The pic shows the mini sized D1 clone I/U + buffer stage. Fully symmetrical (4 "channels") and two voltage regs a la P1.7 in the middle. The 610/9610 lock somewhat pressed in, because I originally layouted for smaller FETs. The sound is unbelievable nice. I trust in Nelsons circuits and just copy them.
Hopefully the other day a nice, small PCB would be available for this stage. Small to bring it into given packaging situations. By adjusteing two Rīs and the filter cap it can easily by adapted to each DAC with symmetrical current output.
Klaus
Old 12th January 2004, 10:28 AM   #28
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
How can I implement the D1-Stage with an Ultra-Analog-DAC (parasound 2000)? How can I implement the D1-Stage with an Ultra-Analog-DAC (parasound 2000)?
Great work, I knew the TDA1547 could perform...
-waiting for the PCB...
Arne K
Don't believe everything you think...
Old 12th January 2004, 11:51 PM   #29
Looks indeed great, I would be with the pcb as well.
Old 24th April 2004, 01:47 AM   #30
nar is offline nar
nar's Avatar
Don't wait for the PCB
DIY !
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
How can I implement the D1-Stage with an Ultra-Analog-DAC (parasound 2000)?Hide this!Advertise here!
Looking for Parasound DAC-2000 Ultra schematic Peter Daniel Digital Line Level 9 24th June 2017 12:52 AM
WTB: Ultra Analog D20400A vadimgal Swap Meet 0 22nd November 2008 03:35 AM
Parasound HCA-2000 Problem Burnedfingers Solid State 8 11th December 2007 11:45 AM
schematics from pre-amp stage to implement in cd-player with E88CC in stead of OPAMPS Bas Tubes / Valves 4 11th January 2003 04:08 PM
