Old 2nd February 2014, 12:49 PM   #1
Default F5 monos finished
sound excellent
Old 2nd February 2014, 12:55 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Fugly!
what's temp of heatsinks ?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb ; Papatreasure
Old 2nd February 2014, 01:08 PM   #3
Originally Posted by Zen Mod View Post
Fugly!
thank you !, 50c ,slightly hot due to the mix mash obviously but the backs were all polished and blocked flat , surprisingly low thermal resistance i thought it would be worse, cuz of fin density , stock bias.
Old 2nd February 2014, 01:24 PM   #4
6L6 is offline 6L6  United States
6L6's Avatar
Wow, those look wonderful!!
Congratulations!
Illustrated Build Guides - Pass F4 - Pass B1 - Pass F5 - Pearl 2 - O2 HPA - Hagerman Bugle 2 - Pass Aleph J - Me at BA '13
Old 2nd February 2014, 01:26 PM   #5
Zen Mod's Avatar
It looks interesting , no doubt
however - having some air circulation through box is mandatory , same as arrangement where fins aren't blocked from below and above
take care of openings in bottom and top plates
same for area of plates below and above of fins
if nothing else , make sort of Babysitter* pedestals , with strategically positioned vents
* look for mine Babysitter at Forum
Old 2nd February 2014, 01:43 PM   #6
thank you 6L6!
Zen i had a look at the "babysitters" and they are quite a good idea , it is difficult to punch holes in the black ceramic tile , but the back panel is acrylic and i can easily vent it.
Old 2nd February 2014, 01:56 PM   #7
Zen Mod's Avatar
if you have enough material for second set of fronts , you can make taller ones , then put some spacers between bottom and top plate and rest of chassis
say that 5mm spacers will give you enough airflow (5mm slit around circumference ) , in which case you need at least 10mm taller fronts
Old 2nd February 2014, 02:01 PM   #8
i just may have enough material for a second set of fronts , that is an excellent idea.
Old 2nd February 2014, 02:03 PM   #9
Zen Mod's Avatar
like majority of mine ideas
though , minority of them is significant enough to diminish previous ones
Old 2nd February 2014, 02:12 PM   #10
hahah
Another F5 finished jt1000 Pass Labs 15 8th March 2012 04:36 PM
Finished F5 maartentje Pass Labs 14 7th March 2011 06:32 PM
Vaic 52B monos KaDe Tubes / Valves 6 8th May 2008 07:50 PM
About how much would dual monos cost? Fryguy Chip Amps 4 7th August 2003 05:41 AM
My ZenV4 Monos Orgonom Pass Labs 21 5th March 2003 05:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
