Curly-F4
Curly-F4
Old 6th March 2014, 04:32 AM   #51
lhquam is offline lhquam  United States
I did another set of harmonic distortion measurements of 3 different front-ends for the F4. The front-ends are:
  • BA3-FE
  • Impasse
  • Curly-F4
Below are the spectrum plots. I am not sure why my BA3-FE implementation has such high H3. The MOSFET bias currents are 50ma as per spec. The MOSFETs are FQP3P20 and FQP3N30. My F4 power supply voltage is a bit low at 22.5V.
The Impasse and Curly-F4 sound much better than the BA3-FE. I currently give the Impasse the edge on sound quality.
File Type: jpg Impasse-swap-F4build1-20140304-sweeps2.jpg (235.4 KB, 669 views)
File Type: jpg CurlyCD-F4CD-Assembled-H2tweak-sweeps.jpg (228.8 KB, 648 views)
Old 7th March 2014, 06:07 AM   #52
rolandong is offline rolandong  Philippines
Wonder if someone who has heard Impasse vs. F6 compare.
Pinoy ikaw ay pinoy... ipakita sa mundo... kung ano ang kaya mo...
Old 8th March 2014, 09:12 AM   #53
Sky63 is offline Sky63  Czech Republic
I have a big request - can anyone compare the sound Aleph J and F4? I'm thinking about building and I cannot decide. Single-ended mode – yes, or not? I am only interested about sound description, not power or something else. Thank you.
Old 8th March 2014, 09:22 AM   #54
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Curly-F4
Aleph J is amp with gain , so having some of own sound signature
F4 is power buffer , without voltage gain ....... and completely embracing sound signature of preceding voltage gain stage (preamp)
so - direct comparison isn't possible .......... while judging Aleph J on it's own , you need to judge preamp/F4 combo
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th March 2014, 11:04 PM   #55
gl is offline gl  United States
Hi Ihquam,
Those graphs represent a serious amount of work. Thank you for posting them.
I am building a BA-3B + F4CR and I have to say that your results are somewhat discouraging.
I'm using the 313/2013 pair and I will place my faith in the hope that they will improve the sound over the Fairchild parts.
Graeme
Old 30th March 2014, 10:49 PM   #56
Default A/B listening tests
This post reports A/B testing of the Impasse+F4 vs. Curly+F4. The Curly gain stage is a variant of the LSK Pre without an output buffer, intended to drive an uncrippled F4.
I recently finished my A/B preamp+amp testing setup. It consists of two DPDT 24V DC relays to switch the speakers between two amplifier outputs, and a pair of trimmer pot attenuators for the inputs to one of the preamps (the Impasse in this case). The relays are controlled from the listening position with SPST switch at the end of a 16 foot telephone extension cable. The trimmers were carefully adjusted for identical amp outputs at 1kHz. With the gains balanced, flipping the switch is virtually undetectable.
I have listened for many hours to a variety of music and cannot repeatedly detect any differences between the Impasse+F4 and the Curly+F4.
I would like to do similar tests using my STAX Lambda Pro headphones without the F4 amps to better isolate differences between the two voltage gain stages. This could be done by using a stereo RCA switch box to select between the two front ends, and attenuating the output to the STAX by about 10:1.
Old 22nd March 2018, 11:46 PM   #57
Telstar is offline Telstar  Italy
Did you?
4x gain is all I need in my chain and I would like to build the F4.
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 23rd March 2018, 01:06 AM   #58
Wow. This thread has been dead for a long time.
I believe that I did some STAX Lambda Pro comparisons that were positive. However, it has been 4 years, and I cannot recall the sonic differences between the F4 and the STAX.
Old 23rd March 2018, 01:10 AM   #59
Yeah, i did a google search on F4 and gain.
Moreover I found some variants with other power devices that look even better to me.
Old 24th March 2018, 04:58 PM   #60
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Curly-F4
It's a nice design. I'm happy to see it resurrected.....
Curly-F4Hide this!Advertise here!
Minuet S52 Curly Cherry Veneer Clearwave Audio apoopoo999 Swap Meet 5 22nd August 2012 02:56 PM
FS: 2-way Curly Cherry (rare) SB Acoustics 5" and Scan Speak tweeter! A must see Jed Swap Meet 4 16th November 2011 12:04 AM
first watt f4 help me!!!! mosfet1 Pass Labs 2 18th May 2008 06:44 AM
F4 and DAC? Flecko Pass Labs 9 23rd February 2008 09:57 PM
FS Feeler: Curly maple component stands TurboFC3S Swap Meet 6 5th September 2006 06:34 PM
