Curly-F4
Curly-F4
Old 29th January 2014, 01:03 PM   #21
lhquam is offline lhquam  United States
In post #1, I forgot to list the Impasse Preamplifier ImPasse Preamplifier as a suitable F4 gain stage. I have built the Impasse and it sounds very good.
Old 29th January 2014, 01:21 PM   #22
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Curly-F4
you can edit #1
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 29th January 2014, 01:39 PM   #23
Originally Posted by Zen Mod View Post
you can edit #1
Thanks ZM. Is there a way to move the schematics from post #10 to posts #1 and #2 respectively?
Old 29th January 2014, 01:41 PM   #24
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
you can edit #1
(we'll have to start callin you MrZ)
Old 29th January 2014, 01:47 PM   #25
juma is offline juma  Germany
juma's Avatar
Originally Posted by lhquam View Post
... I need do look more carefully at the end-to-end square wave response to see if your use of an RC snubber might be useful.
I doubt it - I used it as a precaution because my prototypes were very messy, but nevertheless stable...
Old 29th January 2014, 02:13 PM   #26
Zen Mod's Avatar
Curly-F4
you can put whatever you want in #1 , but for later ones - just use report button in particular post
that way Mods will read it , eventually
Old 29th January 2014, 05:39 PM   #27
NYCOne is offline NYCOne  United States
I could be missing it, but these seems little difference between the Curly and the LSK preamp. For the less well versed of us, can someone point out what the real differences are?
Old 29th January 2014, 05:49 PM   #28
The topology is identical (without the output buffer). The difference is only in the choice of operating voltages, currents, and resistor selection. What I am reporting is the actual integration into an F4 and its end-to-end performance.
Old 29th January 2014, 07:29 PM   #29
juma's Avatar
... actual integration into an F4 and its end-to-end performance.
And you did great. Preamp like this is what the F4 is actually made for. It's easy to get higher voltage rails (needed for the preamp) from F4's transformer so the integration is easy and straightforward and the basic idea (high linearity, no feedback loop) is well preserved. Well done !
Old 29th January 2014, 08:22 PM   #30
Originally Posted by juma View Post
\ ... It's easy to get higher voltage rails (needed for the preamp) from F4's transformer so the integration is easy and straightforward ... !
Thanks for the complements. Are proposing a voltage doubler using the F4 transformer? I hadn't considered that, but given that less than 50mA is required from each higher voltage rail, that should be easy. I just used a Hammond 229B88 transformer which has a pair of 44V secondaries.
Curly-F4Hide this!Advertise here!
Minuet S52 Curly Cherry Veneer Clearwave Audio apoopoo999 Swap Meet 5 22nd August 2012 02:56 PM
FS: 2-way Curly Cherry (rare) SB Acoustics 5" and Scan Speak tweeter! A must see Jed Swap Meet 4 16th November 2011 12:04 AM
first watt f4 help me!!!! mosfet1 Pass Labs 2 18th May 2008 06:44 AM
F4 and DAC? Flecko Pass Labs 9 23rd February 2008 09:57 PM
FS Feeler: Curly maple component stands TurboFC3S Swap Meet 6 5th September 2006 06:34 PM
