Curly-F4
Curly-F4
Old 29th January 2014, 02:25 AM   #11
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Dual 8" 10.08 profile from HeatsinkUSA per side would take the heat at bias up to 2.4A with 22V rails. Lot of heat, but difference between cumulative heat of all fets(majority of heat is external to get) vs heatsink fighting to get rid of high internal heat of fets. Already have output stage designed. Dropped it to finish other things.
...Shape the sound , Man!
Old 29th January 2014, 02:39 AM   #12
lhquam is offline lhquam  United States
Buzz: You handle the heat, I can supply the gain stage!
My Curllian-F4 PCB is actually fabricated as a pair of channels that have interconnects for balanced operation. The entire pair can be mounted (somewhere) and fed to the balanced F4 pairs, or can be split, with wire (or pair) interconnecting for the "X-node".
Old 29th January 2014, 02:50 AM   #13
buzzforb's Avatar
I had the funny^6 on a similar setup with 27V rails and 1A bias. 50W+ per sink, 100W per channel. I can see if we can configure a good working layout. All together, appx size of xa60.5.
Old 29th January 2014, 03:00 AM   #14
rolandong is offline rolandong  Philippines
lh,
Nice build, how was the sound compare to BA3 and Impasse?
Pinoy ikaw ay pinoy... ipakita sa mundo... kung ano ang kaya mo...
Old 29th January 2014, 03:15 AM   #15
Originally Posted by rolandong View Post
lh,
It sounds great, and has NO audible noise with the ear against the speaker.
So far, my listening tests indicate no problems. I prefer the Impasse to the BA3GS, but I have not A/B tested the Curly4 vs. the Impasse. I have another, uncrippled F4, an Impasse, and a BA3GS. For A/B testing, all I need is switches between the amps and the speakers, and some way to equalize the gains.
Old 29th January 2014, 03:29 AM   #16
I'll look forward to hearing how it goes.
I got an Impasse+F4 parts here waiting but not much diy time
The LSK pre everyone's been looking at could mate with F4, too.
Thanks for sharing your build.
Old 29th January 2014, 07:54 AM   #17
henryve is offline henryve  South Africa
henryve's Avatar
Stupid question maybe: where do the other ends of R62 and R63 tie to?
Old 29th January 2014, 09:35 AM   #18
They tie to the ends of the trimmer pot, ie. the JFET source pins. I am not sure what resistance would be best.
Old 29th January 2014, 09:57 AM   #19
juma is offline juma  Germany
juma's Avatar
Originally Posted by lhquam View Post
...The following preamp designs are also interesting, but do not produce 20 volt peak output...
For the truth's sake, the LSK pre does produce more than that. It's just a matter of few different PS and resistor values - look at the post #25 of the said thread (higher gain => tighter bandwidth and vice versa)...
Otherwise, nice build
Old 29th January 2014, 02:00 PM   #20
I stand corrected. With PS voltage and resistor values adjusted, there essentially no difference between my Curly gain stage and your LSK pre (without the output buffer). I need do look more carefully at the end-to-end square wave response to see if your use of an RC snubber might be useful.
Curly-F4Hide this!Advertise here!
Minuet S52 Curly Cherry Veneer Clearwave Audio apoopoo999 Swap Meet 5 22nd August 2012 03:56 PM
FS: 2-way Curly Cherry (rare) SB Acoustics 5" and Scan Speak tweeter! A must see Jed Swap Meet 4 16th November 2011 01:04 AM
first watt f4 help me!!!! mosfet1 Pass Labs 2 18th May 2008 07:44 AM
F4 and DAC? Flecko Pass Labs 9 23rd February 2008 10:57 PM
FS Feeler: Curly maple component stands TurboFC3S Swap Meet 6 5th September 2006 07:34 PM
