F5 with 2sj162 2sk1058 ? - diyAudio
Old 22nd January 2014, 07:04 PM   #1
Default F5 with 2sj162 2sk1058 ?
any one built a pass F5 with 2sj162?
possible? any modification to the circuit?
Old 22nd January 2014, 07:11 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
already done with laterals
however - their Xconductance is lower , comparing to verticals;
less OLG , so less feedback , different THD spectra
'cause I didn't compared it with original , can't say what's difference in sound
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 22nd January 2014, 09:16 PM   #3
could you post any schema or bias resistor mod for it?
Old 22nd January 2014, 10:21 PM   #4
juma is offline juma  Germany
juma's Avatar
Use the Ohm's Law - if your JFETs work at Id of, say, 5mA and you need 2V of Vgs to bias the LATFETs at about 1A you'll need JFETs' drain resistors to be around 400 R (use 1k multi-turn pots and omit LATFETs' Rs, NTC and the rest of parts HEXFETs need for thermal compensation). Since LATFETs have lower parasitic capacitance meaning that they need less gate drive than HEXFETs it would be beneficial to use GR grade JFETs (lower ID) since that way their drain resistors will be higher and the OLG won't drop (maybe a little since the GR grade parts have lower gm).
I got good results by using the BJTs in the input stage at the Ic of about 3mA. I proposed that solution few years ago and can't search for those posts now but you can see it in Lazy Cat's thread about VSSA - that's F5 gone BJT with LATFET Source Follower output stage added.
Old 27th January 2014, 07:52 AM   #5
to avoid one extra stage, going only with J74GR the gain will be too low?
I could reduce the feedback resistor, but then distortion will be higher?
how will it sound?
found one schema of a sort of it but with even less gain and no feedback:
Old 27th January 2014, 10:14 AM   #6
juma's Avatar
Not clear what do you mean - can't make F5 with j74 only, what extra stage?...
Feedback net usually employs 2 resistors. Reducing one of them will increase the gain and distortion (and the Id in the input stage too). Again, it's not clear what you really mean ?
how will it sound?
What ? Few ideas are already mentioned and each will sound different...
It's a transconductance amp, like BA-3. Its gain is determined as G=1A/V and the voltage on the speaker will largely depend on its impedance, so voltage gain cannot be declared as high or low since it depends on the speaker.
Absence of feedback makes it what it is. Insert a feedback loop and you'll get pretty standard amp.
Please, try to be more articulate and specific - you'll get more help that way
Old 13th February 2014, 10:13 AM   #7
Sorry I was too fast in writing last time...
I would like to keep the original F5 2 stage design. Avoid to add a transistor stage to drive the 2sj162 2sk1058
Will the OLG be too low with laterals?
Old 13th February 2014, 10:54 AM   #8
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
indra's suggestion to use the LSK pre to drive the laterals
LSK pre - BAF 2013 (post#76)
sometimes we know very little, and sometimes we know too much
Old 13th February 2014, 01:18 PM   #9
juma's Avatar
...I would like to keep the original F5 2 stage design. Avoid to add a transistor stage to drive the 2sj162 2sk1058
Nobody mentioned additional stage to drive LATFETs. Just put them in circuit instead of HEXFETs and do as written in post #4.
No. Maybe lower (depending on input stage parts choice) but not too low.
Old 21st April 2014, 11:21 AM   #10
juma's Avatar
As it usually happens, looking for something else, today I found my F5 version with Lateral MOSFETs that I mentioned in post #4.
Laterals here need no source resistors and no thermal compensation.
3.5mA runs through the each of the input BJTs - BC550C/560C work here great too (matching is beneficial but not mandatory).
Biasing procedure is the same as for the standard version - the only thing different is that you can bias LATFETs somewhat lower (1A is OK) since the absence of source resistors and the specific curvature of MOSFETs' transfer characteristic enables much later (in terms of load current) switching to AB class regime.
Oh, and 4.7mF means 4700uF.
2SK1058/ 2SJ162..and more lanchile Swap Meet 5 4th July 2013 08:02 PM
2SJ162-E and 2SK1058-E 1965GTO Vendor's Bazaar 5 7th August 2012 06:05 PM
LME49811 + 2SK1058/2SJ162 Buslik Solid State 24 15th March 2012 01:45 AM
Anyone know where to get 2SJ162/2SK1058 IN THE US Ivey Parts 8 20th November 2010 12:56 PM
Anyone know where to get 2SJ162/2SK1058 fossil2k Solid State 8 17th March 2008 12:07 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
