Inputs needed for my design of a Circlotron with F6 front end - diyAudio
Old 18th January 2014, 09:57 AM   #1
aoc is offline aoc  Malaysia
Smile Inputs needed for my design of a Circlotron with F6 front end
Hi fellow diyers,
I have not really contributed much and have been mostly a passive participant . This would be my first attempt to start a discussion on an idea i have so please have some mercy on me.
I'll be building a F6 this year after postponing for about a year at the same time I getting a friend interested to DIY his own amplifier and I sort of selected the circlotron for him to build. Why circlotron? well mostly out of curiosity of its sound. Then my mind started thinking more and thought if there was a good way to combine the 2 so at the end of the build, i can compare F6, circlotron and a hybrid of the 2. I also bought a few SONY VFETs just before Nelson Pass showed it in his talk at Burning amp 2013.
I like the F6 for its simplicity and the way the transformer is use as a phase splitter and came up with this schematic. And in trying to adopt a method to minimize the number of device actually use i remove the JFET feeding the final MOSFET in Michael Rothacher's Amazing circlotron's schematic
After that i realize i don't have a good way to create a feedback path since the original publish F6 is single ended; the bufferless balance input version didn't include loop feedback. So my thought was could one of the input primaries be use for feedback as shown in schematic below?
All comments welcome
Alex Oon
Old 18th January 2014, 02:23 PM   #2
I just realize the schematics aren't coming through very well if i link from my picasa web album.
Rev1 is my first attempt but could not quite figure out how to connect feedback loop
Rev 2 is my proposal on using one of the primary for feedback.
Alex
Old 18th January 2014, 03:30 PM   #3
buzzforb's Avatar
Just like F6, but with two feedback resistors, one from each side of the output????Not 100% sure it will work and a bit of a dangerous experiment.
...Shape the sound , Man!
Old 18th January 2014, 03:48 PM   #4
Buzz,
Since the output is 180 degrees out of phase, summing the the 2 resistors in to one port, the 2 signals will effectively cancel each other.
Sent from my C6903 using Tapatalk 2
Old 18th January 2014, 03:59 PM   #5
Buzz,
Well since the output is 180 degrees out of phase, summing (resistor divider for each phase) with the output connected into 1 port, won't it results in no signal/0V being feedback since the exact center of the 2 output is 0V
Alex.
Old 5th June 2015, 02:09 PM   #6
dady is offline dady  Europe
dady's Avatar
Send a message via MSN to dady Send a message via Skype™ to dady
I found today this thread, let me make a question, ordinary the circlotron is a twin follower, this mean that the load is connected to the cathode or to the Source, in the case of Mr Rohacher, he connect to Drain. The output impedance is higher by 4 (?). But the Vfet-valve, has gain over one.
What happen with the curve trace? Is still a triode one or this is not related to the type of connection (G-S-D in common)?
Best REgards
Esteban Bikic
My first front and rear horn loaded fullrange design: help needed from The Wise. maxlorenz Full Range 35 2nd March 2014 01:19 AM
Inputs needed for Power Transformer Design! zgondouin Tubes / Valves 17 15th November 2013 10:58 AM
Circlotron Amplifier Advice Needed Philwait Tubes / Valves 18 17th February 2012 08:13 PM
Bass response design, F3/F6/F8/F10?? alspe Multi-Way 0 4th January 2012 07:49 AM
Larsholt fm tuner front end for JLH tuner design-Any still available? djsb Analogue Source 0 25th December 2008 04:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
