Aleph P 1.7 Volumecontrol Output-imendance question
Old 26th February 2014, 05:32 AM   #21
generg is offline generg  Germany
generg's Avatar
Sorry the data are for the Aleph P, the predecessor of Aleph P1.7 ..... :-(
I forget this sometimes.
The topology is different. The volume controller data might be the same.
and the First Wtt is......a really First Class PSS Idea
Old 9th July 2018, 03:05 PM   #22
sarathssca is offline sarathssca  India
Originally Posted by AudioSan View Post
don't put the attenuator before the aleph. that will result in a noisy preamp. there is a reason that it is behind
In pass B1 buffer preamp and in majority of cases we have the attenuator before the preamp and then followed by the main power amp.
(ie. source ---> attenuator ---> preamp --->power amp)
What is the reason for having volume control / attenuator after the preamp here?
(ie. source ---> preamp ---> attenuator ---> power amp)
Old 9th July 2018, 06:21 PM   #23
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Here is the schematic of the output shunt resistor network.
Old 9th July 2018, 06:40 PM   #24
Hi mr. Pass
Thanks for the schematic of the attenuator ..
Could you please give some info regarding its placement , ie. Between the source and preamp or between preamp and power amp .. or it doesn't matter in either case ?
On b1 the volume potentiometer is between source and preamp buffer and in aleph preamp it's between the preamp and power amp ..
Old 9th July 2018, 06:56 PM   #25
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
P1.7 - attenuator is in after electronic gain stage , meaning on output of preamp itself
besides taking my words as true ........ you can see XLRs on right end of picture
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th July 2018, 01:45 AM   #26
Just wanted to understand what is the reason for putting the attenuator at the end of the preamp instead of at the beginning of the preamp as we more often see, for example in pass b1 preamp .. could you please give some info regarding this ..
Old 10th July 2018, 05:21 AM   #27
AudioSan is offline AudioSan  Norway
The answer is in the line you quoted from me. Aleph P1.7 have some noise.
Old 11th July 2018, 07:42 PM   #28
koja is offline koja  Canada
I think Papa just wanted to take advantage of Aleph P being able to drive any load so he stuck a 1kOhm attenuator behind it, so any noise contributed by the preamp itself also gets attenuated (a purist approach I guess). since that brings the output impedance up shorter leads (up to 3 feet) to the following amp stage are recommended.
Aleph P itself does not like a hot input and there are attenuating resistors with dip switch settings at the input to drop the level if necessary.
Old 12th July 2018, 05:04 AM   #29
PRR is offline PRR  United States
PRR's Avatar
...what is the reason for putting the attenuator at the end of the preamp instead of at the beginning of the preamp as we more often see....
From the now-secret Service Manual:
The volume control system ... ... to achieve good common mode rejection performance, the output attenuation must be matched far more precisely than can be accomplished with potentiometers, and so relays and precision resistors are used.
Yes, this is "different". Mr Pass is known for re-thinking conventional methods. We normally pot first then line-amp, so we won't overload the line-amp.
Pass was working with BIG devices at high voltage. Overload won't happen.
These devices "may" have more hiss than conventional designs (I am not an expert on this). Pot first puts turned-down signals close to hiss. Bringing signal in un-reduced gives best signal/hiss ratio.
We don't normally pot after the line amp (though I know a few which pot before and after, much $$$). With conventional line amps this is a waste of line-amp output, and also messes with the impedance at a point which may be driving long cables. But again Pass was working with BIG devices idling at high power, and these conventional trade-offs were re-thought.
It looks fine to me. Not the thriftiest music-box around, but sometimes that is not the point, the music is.
Old 12th July 2018, 05:58 PM   #30
The one and only
Worth noting, there were additional gain controls via pots between the
Sources of the Mosfets, degenerating the gain, and were used as balance
controls. In spite of better numbers with maximum degeneration, most
users preferred a high gain setting, even if it meant running the output
volume control low.
Aleph P 1.7 Volumecontrol Output-imendance questionHide this!Advertise here!
Volumecontrol hookup Green77 Tubelab 2 28th January 2013 05:33 PM
WTB: Aleph Output boards/Aleph-X rchua77 Swap Meet 0 31st March 2008 04:56 AM
Ucd180 and volumecontrol? iqbad Class D 4 13th October 2006 07:16 PM
Aleph P1.7 output capacitance question Adams_Leo Pass Labs 2 22nd August 2006 12:34 AM
Aleph output topology question mpmarino Pass Labs 3 15th February 2005 06:06 PM
