Selection an amplifier Pass in class "A" - diyAudio
Old 17th December 2013, 09:24 AM   #1
Question Selection an amplifier Pass in class "A"
Hello,
I would like to ask you for advice to select the appropriate amplifier Pass for listening classical music. Now I have Electrocompaniet ECI 2, which is very good.
I'm thinking about amplifiers from Pass Labs Aleph 5, Aleph 3 ...
I listen to mostly classical orchestral music from LPs (large orchestras, symphonies, concerts, ...).
Speakers I have 2.5 band with 65 liter bass reflex, made according the project to Zaph|Audio - ZRT - Revelator Tower. Sensitivity have approx. 90 db impedance is 4 ohms (may also fall slightly below 4 ohms).
I have upgraded turntable Lenco L75 + arm Jelco SA-750D + Shelter 90X cartridge.
Which amplifier will be right for me, Aleph 5, Aleph 3, or which else? Where can I find the most complete project for its construction?
Thank you for your opinions. Milan
Old 17th December 2013, 09:51 AM   #2
Your amplifier is 2 ohm capable (2x150W and 2x90W 4 ohms)
and you would need a massive proper class A amplifier to get
anywhere near its capabilities. As it is it matches pretty well.
Its clearly not Class A beyond a certain point, but that is no
bad thing, its better than just clipping due to low output.
All proper class A designs basically usually can only manage
about half the power into 4 ohms than they can into 8 ohms,
unless specifically built for 4 ohms, and for 4 ohms they
should be designed for maximum output into 3R*.
Also note a higher than normal amplifier output impedance
in this case won't interact much with the broad very flat
impedance of the ZRT2.5, but will interact with bass tuning.
rgds, sreten.
* A compromise for class A, for Class aB you really should
build a 4 ohm amplifier to be able to handle 2R loads well.
I suspect the ECI 2 specs are into R, not nominal ohms.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 17th December 2013, 10:08 AM   #3
Is sufficient a smaller amplifier Power Output approx. 60 watts / ch 4 ohms, I have a smaller room, ECI 2 is not working to full power.
Old 17th December 2013, 10:23 AM   #4
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Considered an Aleph 0 ?
The buck stops Here
Old 17th December 2013, 10:23 AM   #5
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
borrow , listen , decide
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 17th December 2013, 03:29 PM   #6
BobEllis's Avatar
ZM, don't you mean build them all, listen, decide?
ZRT 2.5 way doesn't look like it dips much below 4 ohms. I would consider an F-4 driven by a pumpkin or BA3 front end or an F5T with at least two pairs of output devices. An Aleph J with doubled up output devices should work as well.
Old 17th December 2013, 03:43 PM   #7
PKI is offline PKI  United States
PKI's Avatar
Aleph J, F5Tv2 based on sound preferences. Or BA-3/Pumpie +F4, can't comment here.
Old 17th December 2013, 03:45 PM   #8
KatieandDad's Avatar
I've tried the Aleph 4 and the F5, the Aleph has a far more subtle sound which to me is more pleasing to the ear. However, the Aleph 4 is a far more challenging build. The Aleph 4 is a monster at 100W Class A, it needs huge heatsinks and a huge PSU. ISTR it dumps about 400W of heat into the heatsinks.
Old 17th December 2013, 03:58 PM   #9
400W is a lot of heat to pay for 25W of amp.
The buck stops Here
Old 17th December 2013, 04:36 PM   #10
BobEllis's Avatar
Should be a bit more than 25W with a 4 ohm load, and it will help cut the heating bill.
"WTB" "The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral enantra Swap Meet 3 23rd December 2012 06:36 PM
New Amp "ULTRASYMMETRY" from Nelson Pass - still a Concept Amplifier? tiefbassuebertr Pass Labs 23 30th October 2012 08:02 AM
Building "The Wire AMP" Class A/AB Power Amplifier" wirewiggler Solid State 12 23rd September 2012 03:40 PM
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 03:35 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
