Old 22nd December 2003, 02:47 AM   #1
lawka is offline lawka  Hong Kong
Default Aleph 2 transformer power rating
Anyone can help to advise the selection of Transformer rating of above item.
Sometimes, the manuals of High End components always indicated likely 100 W at 8£[, 200 W at 4£[ & 400 W at 2£[. It supposed that the power rating of transformer would lead to the end result?
Someone use the 1000 VA for single chanel but I heard most people to choose >=1300 VA. Could anyone advise the caluation to formulate the final result.
Old 22nd December 2003, 04:47 AM   #2
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Im using a single 1000 va Victoria Magnetics Toroidal per Aleph 2 Mono Block.
Old 22nd December 2003, 04:48 AM   #3
mefinnis's Avatar
Transformer (VA) = 2-3 x constant power dissipation of amp
So, for Aleph2 = 3 x 300W
1kVA will be fine.
Mark
See: http://www.passlabs.com/pdf/powersupply.pdf
Old 22nd December 2003, 06:35 AM   #4
wuffwaff's Avatar
Default Re: Aleph 2 transformer power rating
well it does help but in the first place the amp must be able to double it´s power output when you halve the load. This is only possible if the output current doubles. With an Aleph (X or not) the max. output current is a function of the bias and the ac-current gain. Normally you can´t get more than twice the bias as peak output current.
william
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 23rd December 2003, 11:59 PM   #5
trigon's Avatar
I have used 1500W for each channel in my Aleph 4s.
Very relaxed and efortless soundwise, meaning good.
Trigon
Old 24th December 2003, 02:30 PM   #6
jrsun is offline jrsun  United States
Trigon
Where did you get them ?
What is the secondary voltage?
Thanks !
Old 24th December 2003, 03:26 PM   #7
Alain Dupont's Avatar
On the PassLab site, go to
http://www.passdiy.com/gallery/aleph2-p1.htm
You have 3 projects on Aleph 2
1)- Use Toroids 1,5kW 33+33V per channel
2)- Use a 1KVA, 35-0-35 transformer with shielding from Victoria Magnetics. per channel
3)- Used Plitron 1000VA toroids with 33+33V secondaries, this gives about 46 VDC on the power rails per monobloc
Merry X-mas to all...
Alain.
Old 24th December 2003, 05:47 PM   #8
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
Check out my Aleph 2: LINK
If you build a CLC power supply - Get a transformer with 37v secondaries.
Not hard to get exspecially if you are having one built by Victoria Magnetics.
With a CL-60 thermistor on the mains for inrush protection, this
will give you 45 volt rails.
Old 24th December 2003, 06:37 PM   #9
trigon's Avatar
Originally posted by jrsun
Trigon
Thanks !
Hi jrsun
I've got them from Plitron and they are with ground wire and with shieldind cage as well. Primaries are 2 x 100 and 120 and secondaries are 2 x 40V before rectifier.
Here is the pic. and link of my Aleph 4
Trigon
Old 25th December 2003, 05:00 PM   #10
Thanks ! Guys
Confused about a transformer's power rating Atilla Power Supplies 11 16th March 2009 11:18 AM
Hammond power transformer fillament rating pred Tubes / Valves 4 24th January 2008 07:14 PM
OP Transformer power rating guesstimate PeteMcK Tubes / Valves 4 28th January 2006 02:48 AM
What should be the transformer rating in respect to wattage of a power amplifier, rajeev luthra Solid State 38 31st July 2004 05:45 AM
Transformer rating for Aleph 4 merbert Pass Labs 24 10th March 2002 11:31 AM
Page generated in 0.15268 seconds (58.26% PHP - 41.74% MySQL) with 11 queries
