Atlast I have some pictures before the second group buy pcb's are distributed. The following pictures show a baby Aleph-X with 17Volt rails and 4,5 A bias. The transformers are from Reichelt and are 330 VA dual 15V. I used four irfp240 for each channel. With the 17Volt rails things get pretty hot, so I blew some stuff before I got this result
. But replacing the heatsinks and making these mono's things worked out fine. The C-R-C filter in the powersupply is 47.000uF - 0.28 Ohm- 47.000uF for both the plus and minus rail. But enough text, here are the pictures:The front of one mono: The interior: The backside: Also I finished my Balanced Linestage (still to be X-ed): ![]() Thanks to Nelson, Grollins, Edwin, Netlist and others for their help. |
#2 |
Nice job Taco,
I like the grills on top. Don't the 0.28 ohm resistors get too hot? Is it two 0.28 parallel? How silent is the output? Any impressions of the sound? /Hugo |
#3 |
diyAudio Moderator Emeritus
Great Job Taco.
![]() You don't need to be humble about that effort. Tell us how it sounds.
Rodd Yamashita |
#4 |
A fine job Taco. Nice and compact.
I too like the grill top. I'm looking for something like that for my next amp. (Haven't found the grill material though. )How does it sound, and hot does it run? Cheers, Dennis |
#5 | |
Check here under "Raw Materials and Springs-Metals-Metal and Thermoplastic Cloth and Perforated Sheets": http://www.mcmaster.com/ http://www.mcmaster.com/param/asp/ps...8=521,158=6215
Rodd Yamashita |
#6 | |
Rodd, Thanks a bunch! Dennis |
#7 |
Looks very nice.
Which boards are those? The famous Aleph-X boards which are being ordered again? How much power did you get with 4 Mosfets? |
#8 | ||
Promitheus: This are the famous Aleph-X boards, output power is about 40 Watt according to calculations, 17Volt + bias of 4,5 A. (see for excel-sheet elsewhere) |
#9 |
Ooooh, CRC filter, and a clean, tight chassis layout. Looks like some really nice metalwork, too.Nicely done indeed, Taco!
- Chad. |
#10 | |
Oops, almost missed this one
!Very nice job, Taco ! I know the amp is dead silent, but weren't you afraid by locating the IEC inlet so close to the inputs ?. It's something I search to avoid, but surely the balanced connection helps a lot Quote:
Congrats again.
/Cheff - Falling feels like flying, until you hit the ground |
| Greetings from the Netherlands! | andriesva | Introductions | 3 | 22nd February 2008 05:58 PM |
| Hello from The Netherlands | halfgaar | Introductions | 1 | 25th March 2005 06:27 AM |
| Greetings from the Netherlands | E. Pardaans | Introductions | 5 | 27th November 2004 01:48 PM |
| Also from the netherlands | Sebastiaan | Introductions | 3 | 14th September 2004 03:40 PM |
| New from the Netherlands | martijn | Introductions | 5 | 2nd December 2003 09:28 PM |
| Page generated in 0.14267 seconds (65.60% PHP - 34.40% MySQL) with 10 queries |
