Help! Anyone in Seattle area willing to take on a challenging F5T issue? - Page 4 - diyAudio
Old 19th November 2013, 05:44 PM   #31
The one and only
Nelson Pass's Avatar
Originally Posted by SirByrd View Post
120v in, ~.32v across source resistors, .8A draw from the wall. 5mV of dc offset. Heatsinks are about 100F 37C with the top on. Music plays.
Now doesn't that feel good?
Old 19th November 2013, 06:06 PM   #32
6L6 is offline 6L6  United States
6L6's Avatar
Doesn't seem to blow the fuses, I think I'll just keep in the smaller fuses.
It will, in time.
Old 20th November 2013, 05:47 PM   #33
Did you build those cases yourself or are they available somewhere? They look great!!!
Old 20th November 2013, 06:08 PM   #34
SirByrd is offline SirByrd  United States
SirByrd's Avatar
I designed them myself, including custom machining done to the Conrad heatsinks.
If you want to replicate them I can PM you the front panel express files, which should also work at their parent company which is based in Germany (cheaper shipping for you)
Old 20th November 2013, 06:41 PM   #35
Thanks for the info, I have something very similar designed for a future project, if it were available on the shelf would be much cheaper.
Old 20th November 2013, 08:32 PM   #36
SirByrd's Avatar
Yeah, with heatsinks it was about $1400 for both cases, not including the guts.
Old 21st November 2013, 12:47 AM   #37
expert in tautology
bear's Avatar
Sweet little amp case there!
I'd change and increase the gauge of the ground wires on those caps by a WHOLE LOT. Like 10ga would suit me fine.
Also take your ground wires and somehow in that design create a very short "tab" off the center point to connect to, rather than spreading the connections, or having any connections elsewhere, including on the tabs of the caps... assuming you continue with this physical connection method, that's how I'd work it.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 21st November 2013, 03:02 AM   #38
Excellent Byrd, glad its working. As we discussed on the other forum, and despite what the naysayers say, your amp was not having an oscillation problem. Things would have smoked if you did. As I told you, Peter Daniels said up to 12 inches with the standard F-5 would be no problem. This wasnt directed to a turbo version, but the F-5 is also a very wide bandwidth amp. Easy fix, glad its working properly.
russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Old 27th November 2013, 07:48 PM   #39
SirByrd's Avatar
russellc
Yes, I didn't think it was going to oscillate, since I built my first F5 this same way.
Newbie from the Greater Seattle Area skeeter99 Introductions 2 4th January 2011 05:24 AM
Ward from Seattle area ward cleaver Introductions 3 29th December 2009 03:15 PM
Murphy Usher two way FS Seattle area vaughn Swap Meet 2 6th August 2009 05:11 PM
Table saw in the Seattle area? cwujek Full Range 6 8th February 2008 07:58 PM
Invitation to Seattle area DIYers Timn8ter Multi-Way 56 3rd April 2004 01:31 PM
Copyright 1999-2017 diyAudio
