Amp Camp Amp...built it, but no power. Need help troubleshooting!
Old 5th November 2013, 07:21 AM   #1
jamesbythebay is offline jamesbythebay  United States
Default Amp Camp Amp...built it, but no power. Need help troubleshooting!
Hi all,
I finished my slow...meticulous..assembly of the ACA kits. Everything is double and triple checked for proper parts placement and polarity. The switches and power supply inputs appear to be wired correctly.
I flip the on/off switch. No light. Less than one vac between Q1 and ground. When power is switched off, vac at power connection measures 10.25v.
Both amps measure the same. I've tried both power supplies. Same results.
Any thoughts on troubleshooting?
~james
Old 5th November 2013, 09:26 AM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
How to Transfer Images from a Digital Camera to a Computer
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 5th November 2013, 10:34 AM   #3
Bones13 is offline Bones13  United States
Techie Wanabe
Bones13's Avatar
I agree with pictures needed. The PSU (laptop power bricks) output DC only. I'm no expert, but I can make mine look like pictures here. Be sure the right transistors are in the right place, and cap polarity is correct. Get a DC volt measure of the power at the jack, switch, and at the power in spots on the boards.
W4S STP-SE - DIY Aleph J - Zu Audio Druid V + Undertone
(Analog) VPI Scout Sig - K&K Audio Maxxed Phono (Digital) microRendu - Bryston BDA-3
Old 5th November 2013, 06:02 PM   #4
Hey Bones & Zen,
Thank you so much for reading and replying to my really late night post! After getting a bit of sleep and thinking on Bones reminder that the PS was outputting VDC (thank you!!!) and not VAC, and that I was having the exact same set of symptoms with both amps, I pulled out the 'ol Fluke, made a couple of voltage measurements and then fixed the problem.
The failure to power up problem was caused by not connecting the ground lead (from the board) to the proper pin on the power jack. There are three blades. The center pin is positive DC. Clockwise, as one looks at the pin side of the jack, the next blade is negative DC. The third blade, again clockwise, is unused. The diyaudio ACA build guide states "Solder a black wire from the point marked GND to either of the remaining tabs on the power jack." I did this, and got unlucky enough to choose an unpowered blade on the power jack. Two lead swaps later, I was measuring 10VDC at Q1/GND. Yay!
I measured every single part for continuity, specs and polarity...except the power connector.
It's always that last one that gets you...
Right now these two little cuties are baking away on the bench. The voltage is slowly drifting upward. Life seems to be righting itself...
Thanks again guys.
Old 5th November 2013, 07:44 PM   #5
Techie Wanabe
Bones13's Avatar
I will admit that I spent a lot of time inspecting the blades on the power jack before installing/soldering anything.
Old 5th November 2013, 08:47 PM   #6
Zen Mod's Avatar
Amp Camp Amp...built it, but no power. Need help troubleshooting!Hide this!Advertise here!
My desk amp - “Amp Camp” - Aleph current source OR??? knutn Pass Labs 28 19th September 2015 03:02 PM
Amp Camp Amp #1 – A Pictorial Build Guide N Brock The diyAudio Store 1 28th September 2013 08:23 AM
ACA - Amp Camp Amp, Bridged or Balanced ? Rixsta Pass Labs 2 14th July 2013 04:14 PM
Rockford Power 500.2 Amp Troubleshooting power supply. kds9591 Car Audio 6 3rd September 2008 03:09 AM
SDS Labs Headphone amp. Anyone built it? can it be converted to a power amp? JCoffey Headphone Systems 1 30th May 2003 12:11 PM
Copyright ©1999-2017 diyAudio
