Two B1 questions
Two B1 questions
Old 31st October 2013, 02:24 PM   #1
wyan is offline wyan
Two B1 questions
Default Two B1 questions
1. Unit gain.
I just finished building a first Watt B1, I seem to only to get 80% volumn comparing to source directly connected to power amp. Is this normal? What could be the issue? Will a better potentiometer solve the problem and bring out about 100%?
2. Battery supply.
I am using linear power supply. Will battery supply improve the performance significantly?
Thanks.
Old 31st October 2013, 02:33 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Two B1 questions
1. what source exactly (voltage , output impedance ) ?
2.not necessarily ; why not try it ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 1st November 2013, 03:10 PM   #3
Two B1 questions
Zen,
Sorry my bad. I sold off my previous setup and am starting from scratch. Therefore right now the source is computer and I actually used Sennheiser HD250 headphone. I guess that was why. I will soon found out when my full range drivers arrive in a few days.
Just to make sure, I guess we should be able to get close to unit gain? Thanks again. )
Old 9th November 2013, 03:57 PM   #4
Two B1 questions
I received Lowther PM4A and am still waiting for woofers. To do a quick test I connected PM4A to DIY F5 and B1, and then a Studer D730 player. I am very pleased with the result. I actually compared B1 to a Jeff Rowland Capri. There is no much difference in EVERY respect (I am not able to compare the bass performance though). B1 may actually have a bit better sound stage and Capri has a bit better control. But then I believe B1 would be a better choice when I upgrade my CD player or DAC.
Many thanks to Nelson for offering so many great stuffs. Cheers.
Old 9th November 2013, 04:16 PM   #5
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
The B1 is pretty immune to supply quality. There is a case of diminishing returns if you want to spent a lot of time and money in providing it with Diamond Crusted Perfect DC.
A good LM317 regulated 24V supply with decent caps will be better than a cheapie SMPS walmart but after that - as I said, the returns are very minor.
Old 9th November 2013, 04:27 PM   #6
Two B1 questions
Thanks. I guess I will live with the current version for a long while then.
Two B1 questionsHide this!Advertise here!
Pot > B1 > step up transformer > B1? sharpi31 Pass Labs 19 20th October 2013 01:45 PM
6 real quick (mostly yes or no) questions about the B1. osd1 Pass Labs 14 24th August 2013 04:38 PM
The B1 Buffer and F5 Build intergrated, questions Rixsta Pass Labs 21 21st March 2013 02:32 AM
Mesmerize B1 vs Original Pass B1 - please guide me! KT Pass Labs 9 6th September 2012 05:57 PM
B1 Help Puffin Pass Labs 7 23rd November 2011 10:40 AM
Copyright ©1999-2017 diyAudio
