Six output pairs with standard F5T front end? - diyAudio
Old 29th October 2013, 09:32 PM   #1
dhenryp is offline dhenryp  United States
Default Six output pairs with standard F5T front end?
The standard F5T V3 drives four pairs of parallel output transistors. Could I use the standard front end to drive six output pairs?
Old 29th October 2013, 09:42 PM   #2
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
you can always double input Jfets
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 29th October 2013, 09:53 PM   #3
I could but do I need too?
Old 29th October 2013, 09:55 PM   #4
Zen Mod's Avatar
need ?
no
Old 30th October 2013, 01:01 AM   #5
well. i would not use a single pair of 8mA fets to drive 6 output pairs as far as i remember, 8mA is about minimum for 4 output pairs.
Old 30th October 2013, 11:40 AM   #6
Well, I have one yes and one no. Anybody else have an opinion?
If I do have to go for parallel driver FETS, can somebody point me to an explanation of how to do it? I assume it would need some kind of source resistors to account for imperfect matching.
Old 30th October 2013, 12:06 PM   #7
fpitas is offline fpitas  United States
Since you're adding capacity by paralleling more output devices, the output slew rate will suffer unless more drive is available. Not a show stopper, but undesirable for best fidelity.
Old 30th October 2013, 01:32 PM   #8
The following is the brief discussion about adding parallel output stages by NP from the F5Turbo paper:
“That said, the capacitance of the output stage devices starts to pile up and the bandwidth starts to go down. If I can get 800 Khz bandwidth from this amplifier with 2 pair of devices, then I might expect something on the order of only 80 Khz from 20 pair.”
I assume that this is the slew rate issue that fpitas talked about. It seems that with 6 sets of output devices I could expect a bandwidth of 800 Khz/3 = 266Khz. That seems to me to be more than adequate for my use.
“Even this is not much of a barrier – we simply parallel input Jfets to raise the current available for driving these devices and decrease the impedance of the feedback loops. After about 4 sets in parallel you need to give them Gate resistors to avoid parasitic oscillation and you are good to go - probably to 500 watts or so into 8 ohms and more into lower impedances.”
Is the “4 sets in parallel” NP is talking about four sets of input JFETs in parallel or four sets of output FETs in parallel? I’m guessing he means input JFETs so this wouldn’t apply to me if I used 2 sets of parallel input JFETs.
Is the “decrease the impedance of the feedback loops” NP talks about mean changes that I need to make to feedback resistors? Which resistors and how would I go about calculating new values?
So back to my original questions;
1. If I can live with the ~266Khz bandwidth (I can), can a single pair of input JFETs drive sufficient current for six pairs of parallel output devices?
2. If a single pair of input JFETs can’t handle six output pairs, how do I go about modifying the schematic to add parallel input JFETs? Do I literally just put the additional JFETs in parallel with the current devices or are there additional components I need to add or change value?
Old 30th October 2013, 01:52 PM   #9
If you match the input JFETs reasonably closely, you can probably get away with just paralleling them; but it probably wouldn't hurt to add individual source resistors of a few ohms (say, 3.3 ohms).
Old 30th October 2013, 03:44 PM   #10
fpitas - Thanks for the response. Can I infer from your post that you don't think a single JFET pair could drive 6 output pairs?
Latest project SRPP valve front end with class D MOSFET output stage. nigelwright7557 Tubes / Valves 1 3rd May 2013 06:15 PM
HK 'Deuce front end on G2 drive output stage? GordonW Tubes / Valves 0 9th June 2008 02:22 PM
A75 front-end unwanted output signal ckwong99 Pass Labs 1 29th December 2007 09:28 PM
Elektor op-amp front-end with mosfet CF output stage Dusk Elektor 1 5th April 2006 04:09 AM
Hybrid tube front end and transistor output stage Burnedfingers Solid State 6 4th April 2004 11:28 PM
Copyright 1999-2017 diyAudio
