Old 20th October 2013, 02:17 AM   #1
Default B1 to F5 and subwoofer
I want to try hooking up a subwoofer along with the F5 amp to the outputs of a B1 buffer. The subwoofer has a single input.
I've read a few threads here at diyAudio and other articles on the net.
Some say I can connect the outputs of the B1 with a simple Y cable since it has 1K series resistor on the output. Others say I need a summing amp because just connecting the outputs will cause crosstalk between channels.
Thanks for your help!
Old 20th October 2013, 09:49 AM   #2
Use an inverting "summing" circuit to combine the L & R, for a mono feed to the bass only amplifier/speaker.
regards Andrew T.
Old 20th October 2013, 08:47 PM   #3
I know little about and have never worked with op-amps. Can you please point me in the direction of something more than a schematic.
Old 21st October 2013, 08:03 AM   #4
Mono Summer Module
is a balanced to balanced summer.
Op Amp Summing Amplifier
is an unbalanced to unbalanced. I found the links work with being registered.
Note that the centre section of the balanced is the same as the unbalanced.
regards Andrew T.
Old 11th November 2013, 02:07 AM   #5
I did this circuit on a breadboard. It's made with two LM 741 op-amps I bought at Radio Shack. This first one develops the positive/negative voltages needed for the second op-amp. The second op-amp is the inverting summer. R1 and R2 are 10K as shown. I experimented with R3 which ended up being 5K, which gives me 1/2 the sum of the voltages V1 and V2. It seems to work great and was fun to build. Now I just need to put it on a circuit board in an enclosure and replace the bench supply with a something permanent.
Thanks AndrewT.
I guess this thread could be moved. It doesn't really have anything to do with Pass Labs anymore.
Old 13th November 2013, 09:53 AM   #6
If you set R4 to equal the parallel combination of R1||R2||R3, then the opamp output offset is minimised if the opamp is perfect.
For R3=5K and R1=R2=10k then R4 should be ~2k5 for minimum offset.
You will find that R4 needs slight trimming for least offset because all opamps are not perfect. It could be higher or lower. 2k4 is probably close enough.
regards Andrew T.
FS: F5 +B1 + EAD DSP7000 tolikas Swap Meet 8 21st February 2014 11:16 AM
Enhanced F5 / Light Version of F5 Turbo with biasing problem. CLiu Pass Labs 15 26th June 2013 07:16 AM
The B1 Buffer and F5 Build intergrated, questions Rixsta Pass Labs 21 21st March 2013 02:32 AM
Mesmerize B1 vs Original Pass B1 - please guide me! KT Pass Labs 9 6th September 2012 05:57 PM
B1 Subwoofer (mono) out bassnkeys Pass Labs 4 22nd September 2011 02:44 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
