ACA Build Question
ACA Build Question
Old 18th October 2013, 10:32 PM   #1
HJL857 is offline HJL857  United States
Default ACA Build Question
Hello i would like to get, a how to opinion, on how to secure the Led to the
pre drilled face plate , i extened the LED hook up wire from the PCB to the back
side of the face plate. its pre drilled hole is larger than the LED and no way of
securing the LED. Any help would be considered so i can attach it.
Thanks much
Old 18th October 2013, 10:42 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
ACA Build Question
either melted plastic (hot glue , whatever) or 2- component glue or atomic bomb
choose .........
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 19th October 2013, 02:08 AM   #3
ZenMod,
Thanks, that's what i was thinking hot glue, i was looking i guess for a
solution like a gromet of some sort, i think i will use the hot glue.
thanks.
HJL857
Old 19th October 2013, 02:24 AM   #4
12B4A is offline 12B4A  United States
12B4A's Avatar
These clips WalterW found work well and are very tidy. Although if you already have hot glue, then there's no shipping charge.
Old 19th October 2013, 03:51 AM   #5
A cleaner more professional way with the clips
another idea, Thanks !
Old 19th October 2013, 05:06 AM   #6
Bones13 is offline Bones13  United States
Techie Wanabe
Bones13's Avatar
ACA Build Question
I used an additional solid core wire attatched to the PCBs mount to position the LED. On other projects, I have used bluetac with great success.
W4S STP-SE - DIY Aleph J - Zu Audio Druid V + Undertone
(Analog) VPI Scout Sig - K&K Audio Maxxed Phono (Digital) microRendu - Bryston BDA-3
Old 22nd October 2013, 03:02 AM   #7
CanAm Man is offline CanAm Man  United States
Clear silicone caulk in a tube......and you'll have enough left over, to fix any leaks around your bathtub rim, too.........
Old 22nd October 2013, 03:05 AM   #8
[QUOTE=Zen Mod;atomic bomb
[/QUOTE]
If you go with this option, just use a low-yield device, and watch out for secondary meson radiation. Best not to wear a good watch, if you "nuke" it.....
ACA Build QuestionHide this!Advertise here!
ACA Amp Questions mstomaso Pass Labs 12 5th January 2014 09:44 PM
BASIC ACA WIRING QUESTIONS HJL857 Pass Labs 7 2nd October 2013 07:27 PM
ACA JFET install Question. HJL857 Pass Labs 13 24th September 2013 06:28 AM
Pass Labs ACA's opa1 Swap Meet 3 2nd September 2013 06:24 PM
ACA with Universal Power Supply bnorrish Pass Labs 4 24th November 2012 10:58 PM
