LSK pre - BAF 2013
LSK pre - BAF 2013
Old 1st November 2013, 12:06 AM   #81
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
LSK pre - BAF 2013
Thanks Juma,
No i intend to use your PSU.
With pre regulator isolated from cap multiplier, this will be in same pcb as preamp and buffer...it seems JC also likes this arrangement.
This is just because the box I've got is from an old Granger aeronautical transmitter...very small and compact, cast alu with internal division in the center....just right i think.
I'll post pictures when done.
Old 8th November 2013, 05:39 PM   #82
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Here is an SMd version I am goign to have made. I have chosen to do the rectification section differently, as I will use a different transformer with dual windings. Want to try full dual mono as this is DIY and excess is the nature of the game. Super low noise stage should use low noise smd and susumu RG will be my choice.
...Shape the sound , Man!
Old 8th November 2013, 07:11 PM   #83
buzzforb's Avatar
Full Monty according to Juma. Can post gerbers if anyone is interested in them.
Old 9th November 2013, 02:37 PM   #84
buzzforb's Avatar
I have read that a pot at the output was suggested by Nelson at BAF. My question is whether or not we should follow it with another buffer?
Old 9th November 2013, 02:39 PM   #85
PKI is offline PKI  United States
PKI's Avatar
LSK pre - BAF 2013
A Volume pot, you mean?
Old 9th November 2013, 02:44 PM   #86
buzzforb's Avatar
One of only two possibilities when it comes to music.
Old 9th November 2013, 03:03 PM   #87
juma is offline juma  Germany
juma's Avatar
Originally Posted by buzzforb View Post
... a pot at the output...
Be careful with it:
1. have in mind that pot's total resistance will be in parallel connection with the resistor that sets the gain.
2.Your preamp will always work in full throttle mode so louder recordings or high level source component will drive it into clipping and you won't be able to do anything about it with the pot at the preamp's output...
3. buffer becomes mandatory after the pot since the 10k pot will (in worst case - at middle resistance position) represent 2.5k series resistance to the next stage (power amp)
Old 9th November 2013, 03:07 PM   #88
buzzforb's Avatar
I would have assume a pot at the input, only asked because someone had commented as such in this thread.
Old 9th November 2013, 04:56 PM   #89
6L6 is offline 6L6  United States
6L6's Avatar
LSK pre - BAF 2013
Nelson did suggest a pot on the output - I remember as it was I who asked. I think it's on the video...
The pot on the output has the advantage of attenuating the circuit noise as well - cool!
I like Juma's ideas, especially with the BJT on the output, and the buffer.
Old 9th November 2013, 05:19 PM   #90
CeeVee's Avatar
LSK pre - BAF 2013
I intend to use a 10K trimmed muse on input.
LSK pre - BAF 2013Hide this!Advertise here!
Pass at BAF 2012 Nelson Pass Pass Labs 37 27th July 2015 11:40 PM
BAF-Streaming video technicalities ashok Clubs & Events 0 10th April 2012 05:07 AM
The Pass room at BAF 2011 Nelson Pass Pass Labs 2 7th September 2011 03:33 AM
What and Where is BAF? Troncones Tubes / Valves 10 16th January 2011 02:30 AM
Baf stuffing > trouble? ALFIrE Multi-Way 2 24th November 2004 10:20 AM
