LSK pre - BAF 2013
LSK pre - BAF 2013
Old 11th April 2018, 08:14 PM   #551
woofertester is offline woofertester  United States
Originally Posted by Hikari1 View Post
I do not. But I have a CD with some tone sweeps...I could use that.
Bu all my sources are cap coupled as well. It really is kind of strange.
Noted. Even so, capacitors leak. It might be worthwhile to use and external cap to rule out the source being a problem.
Old 17th April 2018, 12:16 AM   #552
Chul is offline Chul  South Korea
Default 12 Battery?
Hi Juma,
What is the current consumption of the last circuit with bipolar 12V?
I am always tempted to use batteries.
Chul
Old 17th April 2018, 04:34 AM   #553
Hikari1 is offline Hikari1  United States
Originally Posted by Chul View Post
Hi Juma,
Chul
Juma will probably tell you for sure but there is 10-12ma through the bjt outputs...so maybe 30ma per channel?
Old 17th April 2018, 05:35 AM   #554
Thank you Hikari1,
I have 1400mA Lipo battery packs, and maybe this can be worth trying. I will use the output cap, for (-) (+) voltage may not be the same after a while causing DC offset?
Chul
Old 17th April 2018, 09:58 AM   #555
juma is offline juma  Germany
juma's Avatar
Hi Chul,
you didn't write the post # of schematic that you are interested in, so I'll guess it's a sch. from post #539.
The consumption will depend on Idss of your JFETs and it can be anything from 15 to 25 mA, per rail, per channel (with current through Q6,Q7 set at 10mA)
Offset will drift mostly with temperature, not with small variations of PS voltage.
Read posts from #485 onwards.
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 23rd April 2018, 07:01 AM   #556
Hi Juma,
Thank you for your kind reply. With 1400mA battery packs that I have the current consumption is something that I can live with I think.
I ordered the parts for your circuit.
Old 23rd April 2018, 03:06 PM   #557
Found the problem. It was the power amp, not the pre.
Old 24th April 2018, 04:47 AM   #558
watchtmouse is offline watchtmouse  Germany
watchtmouse's Avatar
Default what was the issue with the power amp
Hello Hikari1,
I like the detailed reports about your journey to your optimal solution. (I have a BA-3 as preamp being build(for way too long now), this one will be the next candidate)
In post #534 LSK pre - BAF 2013 you wrote:
Power amp is very light load (Pass F5T/100K),
Did you change the Power amp or did you fix the issue with the F5T?
When fixing the F5T what did you fix?
Happy listening
Bert
PS, Ah, I see your are stil investigating: F5 dc offset issue
Old 24th April 2018, 04:00 PM   #559
Originally Posted by watchtmouse View Post
Hello Hikari1,
Happy listening
Bert
Yes. It appears I have some jfet leakage on the F5. It makes the DC offset on the power amp fluctuate depending on the preamp used. So, not the fault of Juma's preamp. Which is excellent and I highly recommend it.
LSK pre - BAF 2013Hide this!Advertise here!
Pass at BAF 2012 Nelson Pass Pass Labs 37 27th July 2015 11:40 PM
BAF-Streaming video technicalities ashok Clubs & Events 0 10th April 2012 05:07 AM
The Pass room at BAF 2011 Nelson Pass Pass Labs 2 7th September 2011 03:33 AM
What and Where is BAF? Troncones Tubes / Valves 10 16th January 2011 02:30 AM
Baf stuffing > trouble? ALFIrE Multi-Way 2 24th November 2004 10:20 AM
