Better than a B1...Commercially Available... - diyAudio
Old 13th October 2013, 04:48 AM   #1
chrismercurio's Avatar
Default Better than a B1...Commercially Available...
I have been using a B1 for several years. I'd like something that sounds even better that is commercially available without costing an arm and a leg. That last statement might be tough to deliver on but I thought I'd put it out to the group anyway. I currently use an First Watt M2 with so a preamp with a tiny bit of gain is welcome.
Best,
Chris
Old 13th October 2013, 11:25 AM   #2
There are other buffers on this Forum.
Some get very good reviews.
I fear the only way to find out is to build some yourself.
Not quite meeting your "commercial" requirement.
If you need gain, then you must look at a completely different class of equipment.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 15th October 2013, 03:54 AM   #3
Thanks. I have less time to build these days...
I may need to though.
Old 15th October 2013, 06:10 AM   #4
Default I depends how long your arms and legs arm
To get a better sounding B1, with a bit of gain is a tall order. Run your B1 of off 3 bridges 12 volt batteries with a voltage regulator set to 32 volts. Also the Salis version is supossed to sound better, but I have not tried it yet. Get your gain by using a TVC kit with a 6Db gain tab switch included. I know TemaadAudio do such a kit as I am thinking about buying one myself, or search E/Bay for one
tabarddn
Old 15th October 2013, 06:16 AM   #5
I have an email to Pieter at Tribute to see if he will build a volume control with a step up built in like what you suggest.
Old 15th October 2013, 11:17 AM   #6
Default Tribute ?
What is tribute, cannot find on internet search, any link
tabarddn
Old 15th October 2013, 11:23 AM   #7
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
Tribute - The final word in audiotransformers
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 15th October 2013, 12:32 PM   #8
Tube Cad presents an unusual way to wire a buffer to get 6db gain. Wonder if it would work with the B1 ?
File Type: png inverted%20diamond%20buffer%20topology.png (56.8 KB, 297 views)
Old 15th October 2013, 03:22 PM   #9
Zen Mod's Avatar
different circuit
so , it will work ......... if you change circuit
and then call it B1again , if you insist ......
Old 15th October 2013, 04:27 PM   #10
6L6 is offline 6L6  United States
6L6's Avatar
What about a BA-3 front-end as a preamp? Turning the gain down is pretty easy.
Or the Pumpkin?
Waveguides - 1" bolt on driver and commercially available? John Sheerin Multi-Way 49 19th March 2013 04:01 AM
Dr. Leach Amplifier (commercially being sold?) semper avarus eget Solid State 2 25th November 2011 07:13 AM
Commercially available current dumping amps? Key Solid State 30 23rd May 2009 11:19 PM
SKA, ASKA and LifeForce VS a commercially available amplifier? tinkerguy Solid State 50 11th November 2007 05:09 AM
Copyright 1999-2017 diyAudio
