Amplifiers with series output resistors.
Old 1st November 2013, 03:09 PM   #21
fpitas is offline fpitas  United States
Originally Posted by giantstairs View Post
Thanks fpitas. The gainclone is approx 50 watts and i would like to try values from the, apparently famous, value of 1.5ohms to 47ohms to try to shelve the rising response of my fe108es. Am i better off putting two resistors in series to arrive at the value?
It won't hurt to put two in series, but I can't think of any advantage, except allowing you to tweak the total value a little easier. A 20W 5% tolerance wirewound should easily do what you need, those are only a few bucks each. You can save money and use lower wattage resistors for the extreme values, as those won't have to dissipate as much. You'd have to calculate the power needed for those on a case-by-case basis.
Francis
Old 4th November 2013, 06:41 PM   #22
giantstairs is offline giantstairs  Spain
Thanks!
Old 14th November 2013, 04:22 AM   #23
oon_the_kid is offline oon_the_kid  Malaysia
oon_the_kid's Avatar
Hi Everyone,
Yesterday I got around to sticking a 10 ohm resistor mundorf in series with my Audio Nivana 15 inch full range open baffle that is assisted between 10-20 KHz with a Aurum Cantus G2Si ribbon tweeter.
The sound without/with resistor is night and day. With the resistor, the sound, suddenly became very wide. Without it the sound seems to eminate from in between the two speakers, with it, I no longer have walls at the side... The distinction between the many sources of sound, instruments and vocals becomes more clear. The dynamics is increased, without the resistor the sound feels compressed. The improvement is amazing.
The amp is a class D (class T) Virtue One audio.
Oon
Old 14th November 2013, 11:43 PM   #24
cochleus is offline cochleus  United States
cochleus's Avatar
"It always comes down to the best guess..."
Old 15th November 2013, 01:37 AM   #25
ashok is offline ashok
ashok's Avatar
Would it be a bad idea to use resistive wire itself instead of the wire wound resistor ? Of course it probably wouldn't be copper anymore I guess unless it is single strand and pretty long ( very thin guage ).
Like 36 AWG copper wire would be about 3.5 meters long. Resistance of both forward and return wire taken into consideration. Wattage would be low as it appears it can handle only 4 amps before blowing. Aluinum wire might be thicker and handle more current . But would it sound 'aluminy' ?
AM
Old 15th November 2013, 08:43 AM   #26
nicoch58 is offline nicoch58  Europe
is ligth ! some new speakers coils is in Alluminio
costantine wire is used for DIY resistor
Old 18th November 2013, 01:15 PM   #27
Tyimo is offline Tyimo  Hungary
Hi!
Is this R0 resistor not decreases the driver sensitivity and changges the driver's Qts???
Old 18th November 2013, 02:15 PM   #28
Originally Posted by Tyimo View Post
Hi!
Yes to both; decreases the sensitivity, since some power is dissipated in the resistor, and raises the total Q.
Francis
Old 18th November 2013, 03:06 PM   #29
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
Originally Posted by oon_the_kid View Post
Hi Everyone,
Oon
When you do this with a class D amp (Hypex exception), you will see a rise towards the end of the FR. The reason is that the output filter is calculated for a specific Rload, usually between 4-8 Ohm. Increasing the R of the load leads to an increase of high frequencies.
What you most likely hear in your experiment is this rise in the FR which you could also achieve by using a tone control.
Old 18th November 2013, 06:52 PM   #30
not only.... you change the damping factor ie the controll on the bass .....
Amplifiers with series output resistors.Hide this!Advertise here!
are series resistors a worse choice? PreSapian Parts 4 7th April 2011 10:47 PM
Series Resistors on Outputs of Transformer? Magz Tubes / Valves 10 21st July 2010 09:57 PM
Rickenbacker old amplifiers (b16 series) RODS Instruments and Amps 3 11th August 2009 04:35 PM
Info on Resistors / series resistance one1speed Full Range 7 24th February 2006 02:29 PM
resistors in series starrman93306 Car Audio 6 8th November 2004 09:56 PM
