This may be a silly question, but thought I would ask. I've looked through the old threads and couldn't really find an answer. Will the BOSOZ work with pretty much any power amp? When I build it I will be using an NAD c370, which the power section is the same as the 270 power amp. Eventually I plan on building amps, but just wanted to make sure it would work in the mean time
#2 |
yes it will,
as long as the input impedance is large enough for your planned output impedance. william
een ooievaar is geen konijn want zijn oren zijn te klein! |
#3 |
The imput impedance of the NAD is 20k ohms
#4 |
The one and only
One more time:
Both Boz and Sboz are current source outputs, and are resistively shunted to ground. As a practical matter, for any given input voltage, they will drive even a short with the same amount (actually a little less) of distortion. |
#5 |
Honestly, I'm really learning this ee, slowly. Here is another one im sure has been discussed, but I can't seem to find threads on; what are the implications of adding multiple outputs on the bosoz? I could use two, or even three sets of outputs, and want to afford the possiblity of an active crossover in the future
#6 |
Hi, multiple outputs are fine, I just wired mine up this morning, two balanced and two SE outputs on my BOSOZ; everything in parallel. I don't plan on using them all at the same time, but its nice to have options.
You searched? Did you see the discussion here: Dual outputs for Balanced Line Stage Preamp Note my answer for other things to look out for. |
#7 |
No, I'm sorry, I missed that one, thank you.
#8 |
Kevyjo,
just make shure that your output caps are big enough. The lower the input impedance of your power amp the higher the -3dB point from the high pass will be. william
#9 |
As far as I understand it, the input impedance of the SOZ is only about 5k ohms, if the output capacitance is designed to handle that, Id think it'd do fine with 20k ohms
#10 | |
No , the Son of Zen has the imput impedance YOU will care to use, even higher than 5K. Just choose the resistors you like. |
| To BOSOZ or not to BOSOZ... please comment. | spence | Pass Labs | 4 | 27th February 2012 02:57 AM |
| For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! | opc | Swap Meet | 23 | 2nd November 2009 05:04 PM |
| Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest | mbcouple | Swap Meet | 2 | 27th October 2008 10:27 PM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Page generated in 0.09631 seconds (75.93% PHP - 24.07% MySQL) with 10 queries |
