Aleph 1.2 Trafo question
Old 5th October 2013, 04:34 AM   #1
theduker is offline theduker  United States
theduker's Avatar
Default Aleph 1.2 Trafo question
Hello folks, i am a complete noob, with big dream!
I would like to build aleph 1.2s someday. rest assured i will start with smaller amps, and work my way up. past projects include chip and ice projects, and some crossover modifications.
Although this project is far in the future, it's never too early to assemble parts!
Would a transformer with
Primary:
120V 60Hz
Secondaries:
2 x 60V 18A
2 x 24V 1.8A
And 2246 VA be suitable for an aleph 1.2 build?
I have seen aleph 1.2 boards that call for 50v and 1200va per monoblock. Would this Trafo be unsuitable? Is there a way to step it down or adjust it?
How would the capacitor bank need to be adjusted to accommodate the larger size?
Thanks in advance for the help, I wish I could repay you for it!
Someday I may be able to pass (so to speak!) the knowledge onto others.
I will make another DIY donation when this pipe dream sees fruition.
Old 5th October 2013, 08:47 AM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
if you add one 24V secondary in series with 120V primary , you'll have exactly 50V at secondaries
be careful - you need to connect it (24V) in phase
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th October 2013, 07:02 PM   #3
coolnose is offline coolnose  Europe
coolnose's Avatar
Zen,
I usually "drink" your words (almost) without thinking, but could you kindly develop your thoughts ?
Max
Old 5th October 2013, 07:14 PM   #4
Zen Mod's Avatar
connecting 24V winding in series with 120V winding will give new primary , while un-altered secondaries will ,then, have lower resulting voltage ( n/V ratio in primary is altered , so also for secondary) , ...... so decreased voltage
calc is simple :
for U= ( 60 x 120) / (120+24) = 50
fact that 24V winding is having greater dia wire than primary can't harm .....
Old 5th October 2013, 08:47 PM   #5
WalterW is offline WalterW  Netherlands
Wow, that's a smart idea.... never thought you could do that, putting a secondary in series with a primary...
But what the heck is an Aleph 1.2 ??? 1,2KWatt amplifier?
How many Aleph's variations are out there ?
Found some info, they are huge....24 output devices.. out of my league...
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2
'If you see me talking to myself, don't worry. I'm getting expert advice'
Old 6th October 2013, 12:52 AM   #6
MEGA_amp is offline MEGA_amp
MEGA_amp's Avatar
The 1.2 is a 200w class a beast!! I've always wanted to build one. It dissipates 500watts at idle, so it's really more of an exercise in chassis building, two in this case. You could always could put large value heatsink mounted resistors in the power supply to drop voltage, or use a variac before the transformer.
found some pics of someones 1.2......looks like a wallet eater
DIY Aleph 1.2 - a set on Flickr
another
http://www.diyrealaudio.com/user_rep...ru_12ap_en.htm
build it!!!
I believe there are officially 7 versions: 1.2, 2, 3, 4, 5, 30, 60
I think also the aleph 0, and maybe 1, but they are 3 stage amps vs the above 2 stage.
The cool thing about the alephs is that you can build it any way you like; different voltages/bias/output trannies. The topology between versions are the same, with some resistor value changes and bigger/smaller output stages between versions. I started with the 5, but increased the bias to 5amps, it sounded great, but died a firey death. When I told people that it was 'only' a 60w amp, their jaws dropped.
Aleph 1.2 Trafo questionHide this!Advertise here!
Question about trafo maurycy Power Supplies 31 7th March 2012 02:26 PM
Question - Output Trafo with CFB LinuksGuru Tubes / Valves 32 6th December 2009 08:47 PM
Trafo question... Dxvideo Chip Amps 7 26th September 2007 06:33 PM
230v trafo question giantstairs Chip Amps 7 5th March 2007 02:01 PM
uchcstnigc - trafo positioning question Groundloops Chip Amps 1 18th June 2005 03:11 PM
