BASIC ACA WIRING QUESTIONS
Old 1st October 2013, 06:30 AM   #1
HJL857 is offline HJL857  United States
Default BASIC ACA WIRING QUESTIONS
Hello again,
I am just about to wire up the PCB To the AMP ENCLOSURE, the kit came with 16 gauge 300volt wires
My question is, can you mix 14 gauge wires, 300 volt stranded or solid
would this make any differences in the dynamics of the amp mixing copper wire and i do not know what the kit came with, but its silver in color standed
and solid core. core Again any imput and newbee support would be appriciated thanks diy team !
HJL857
Old 1st October 2013, 09:19 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Yes you can mix the wire types but solid is easier to work with if there is no flexing involved with mounting the board on its chassis.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 1st October 2013, 12:14 PM   #3
Bones13 is offline Bones13  United States
Techie Wanabe
Bones13's Avatar
I had issues with the large wires not passing though some of the various hardware pieces. I found myself removing a few strands in several places. No issues with sound!
W4S STP-SE - DIY Aleph J - Zu Audio Druid V + Undertone
(Analog) VPI Scout Sig - K&K Audio Maxxed Phono (Digital) microRendu - Bryston BDA-3
Old 1st October 2013, 06:28 PM   #4
So if i am using 19 strand wire and 9 strands are missing, would it interfere
with electrical connection? or in the case of Audio,missing strands, would it
comprimise the sound ?, another question why 19 strands ? if missing strands dose not harm circuitry why not just use one stranded thin wire? Im a newB that just wants to know everything,i don't know.
HJL857
Old 1st October 2013, 06:33 PM   #5
Jon,
so mixing stranded and solid core is okay, dose this hold true for different
AWG's on the same PCB or should i say same circuit ?
Thanks for your imput.
HJL857
Old 1st October 2013, 07:57 PM   #6
cbdb is offline cbdb  Canada
You can mix and match all you want as long as the wire has enough current capacity. The only exception is balanced lines, these should be a pair of the same wire. (Including transformer connections.)
Old 1st October 2013, 10:56 PM   #7
Stranded or solid, no issues. Just make sure they will fit through the hole, cutting 8 strands out of 18 is not good!
Old 2nd October 2013, 07:27 PM   #8
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
BASIC ACA WIRING QUESTIONS Send a message via Yahoo to vdi_nenna
I like solid core wire for signal wires, but try to stay away from solid core when wiring power grounds or chassis grounds. Stranded wire has less chance of breaking.
I build, therefore I am.
BASIC ACA WIRING QUESTIONSHide this!Advertise here!
ACA Amp Questions mstomaso Pass Labs 12 5th January 2014 09:44 PM
Basic Passive Sub Question (Wiring) guangui Subwoofers 16 8th March 2013 04:09 AM
Basic Transformer hookup wiring wicked1 Tubes / Valves 3 24th January 2009 01:21 AM
Basic wiring problem Bobhof Parts 2 22nd April 2006 03:51 PM
basic wiring for t-amps HELP! miles488 Chip Amps 3 6th February 2006 09:41 PM
