F5 Build: How much gain do I need? - diyAudio
Old 23rd September 2013, 01:40 AM   #1
KevinHeem's Avatar
Default F5 Build: How much gain do I need?
I'll be using the F5 with a source that produces only 2 volts. Do I need to put R220 resistors in positions R5-R8 for more gain?
Old 23rd September 2013, 02:48 AM   #2
What are you powering with the F5?
Old 23rd September 2013, 02:50 AM   #3
Most relevant: How efficient are your loudspeakers? And what impedance?
Old 23rd September 2013, 03:19 AM   #4
KevinHeem's Avatar
B&W 305 - 8Ω (4.2Ω min.) 91 db
Old 23rd September 2013, 10:31 AM   #5
2Vac with the 6times gain of the F5 results in 12Vac at the output of the F5.
The F5 is capable of a maximum of ~14Vac.
If you want to use that extra 2Vac of output then you need a little extra gain (+1.5dB).
But, will you notice that the amplifier can never clip?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd September 2013, 11:38 AM   #6
flg is offline flg  United States
flg's Avatar
The Max output is specified as + & - 20V in my F5 manual. Gain of 15.3db.
If You are talking RMS Volts of 2, into your F5, then what Andrew says is about right. The + & - 20V maximum output spec is peak volts.
Actually I think the gain is only a factor of 5.5
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 23rd September 2013, 12:40 PM   #7
PJN is offline PJN  United States
You may need to consider using a preamp that can provide sufficient additional gain. With my F5 I found that I couldn't get the volume that I needed with 87 dB spreakers using a typical preamp (gain ~ 10). I ended up building another higher gain preamp (Aikido) and couldn't be happier with the combo.
PJN
Old 23rd September 2013, 12:52 PM   #8
Originally Posted by flg View Post
The Max output is specified as + & - 20V in my F5 manual. Gain of 15.3db............
that should say:
The max output is specified as + & - 20Vpk.
This is equivalent to a sinewave of 14.28Vac.
Gain of 6times is equal to +15.56dB
From [{100//100}/10] + 1 = 50/10 +1 = 6
Gain of 5.5 times is +14.81dB
regards Andrew T.
Old 23rd September 2013, 01:08 PM   #9
flg's Avatar
No argument. But, gain as stated in the original AA article is 15.1db? I'm sure the old "YMMV" applies
Old 23rd September 2013, 01:14 PM   #10
+15.1 is closer to 5.5times, than to 6times.
regards Andrew T.
How to build the F5 6L6 Pass Labs 1133 23rd January 2014 05:32 PM
Which F5 to build? Mark Bartley Pass Labs 12 8th March 2013 12:31 AM
F5 build fred0 Pass Labs 31 21st October 2012 09:47 AM
Fresh F5 Build willamp Pass Labs 25 4th July 2012 03:12 PM
Next suggested build after F5 anilva Pass Labs 36 3rd December 2010 04:11 AM
Copyright ©1999-2017 diyAudio
