Best solder and wire for Pass diy amplifiers ? Best solder and wire for Pass diy amplifiers ? - Page 9 - diyAudio
Old 25th September 2013, 10:08 PM   #81
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Originally Posted by Decker View Post
No matter what wire or solder you use, you won't get a good joint if your components have oxidation. I keep a small piece of fine steel wool on the bench and clean the leads of my components right before installing and soldering them. For large joints, I also put on a little liquid flux. Cleanliness is key to a good solder joint.
YES
Old 25th September 2013, 10:37 PM   #82
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
a lot recently on the JC Blowtorch thread re component cleaning and soldering in general. And do they get in a huff about it!
Old 25th September 2013, 10:39 PM   #83
Soundhappy's Avatar
It simple to clean.
For IRFP i have use anti-static gloves for safety.
Images speaks him self.
Decker thank you for sharing
Have nice day
class A amplifiers with full range speakers
sings like angels in heaven
Old 25th September 2013, 11:25 PM   #84
Decker is offline Decker  United States
Thanks, soundhappy. Brianco, thanks for pointing out that part of the JC blowtorch thread. Interesting discussion. I notice that at least one person thinks that steel wool has contaminants that could interfere with soldering. Based upon this, I am thinking about trying brass wool instead. Or Scotchbrite pads.
Old 25th September 2013, 11:34 PM   #85
brianco's Avatar
My experience of metal 'wool' is that it is lightly oil coated to stop rust/oxygenation. I would not recommend it unless first really cleaned. I just scrape with an old blade. Works for me.
Old 25th September 2013, 11:58 PM   #86
Soundhappy's Avatar
This one from last photos is INOX don't need be protected with oil.Old blade work i have try no chemicals needed is quick i like the result
Old 26th September 2013, 12:10 AM   #87
blossom is offline blossom  New Zealand
blossom's Avatar
I thought this was pretty good soldering/solder equipment and materials info.
EEVblog #180 - Soldering Tutorial Part 1 - Tools - YouTube
EEVblog #183 - Soldering Tutorial Part 2 - YouTube
EEVblog #186 - Soldering Tutorial Part 3 - Surface Mount - YouTube
Old 26th September 2013, 12:15 AM   #88
Triodethom is offline Triodethom  United States
Triodethom's Avatar
Originally Posted by blossom View Post
Impressive 200k to 300k views ! That about 5% of the whole country . Love the accent make a dry subject fun for an old American . Go Kiwi !
Old 26th September 2013, 12:16 AM   #89
Soundhappy's Avatar
This inox wool is made to clean in kichen wet envirenment don't rust have put in the water no problem.
Old 26th September 2013, 12:28 AM   #90
labjr is offline labjr  United States
We call it "stainless".
Best solder and wire for Pass diy amplifiers ?Hide this!Advertise here!
Magnet wire insulation that burns off in solder pot Circlotron Parts 5 17th September 2012 06:38 AM
Wire-Wrap vs. Solder phishead8 Equipment & Tools 12 24th May 2011 02:21 PM
How to solder ground wire to RCA Jack northernsky Construction Tips 13 23rd December 2009 08:27 AM
soldering iron temp and solder wire melting point. jarthel Parts 6 10th October 2006 03:12 PM
Copyright ©1999-2017 diyAudio
