Best solder and wire for Pass diy amplifiers ?
Old 24th September 2013, 10:49 AM   #51
R.I.P.
BTW, she was married and HE was big man, ex rugby player and still a friend.
regards Andrew T.
Old 24th September 2013, 11:43 AM   #52
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
I am like many sunday diyers now i must change to higher quality of solder station.
Weller or Hakko brand with temperature regulation.Please gentlemans what be appriopriate confortable power for most audio assemblings?
Your fetish solder station?
class A amplifiers with full range speakers
sings like angels in heaven
Old 24th September 2013, 08:15 PM   #53
henryve is offline henryve  South Africa
henryve's Avatar
I prefer 350 degrees C for semiconductors and 380 degrees C for resistors and capacitors. I know some will cringe but I prefer hot and fast to cold and slow.
Old 24th September 2013, 08:31 PM   #54
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
Originally Posted by soundhappy View Post
Lead free ?
I have a pound of that solder. What is the ideal iron temperature for PCB stuffing?
Thanks.
Old 24th September 2013, 08:35 PM   #55
brianco's Avatar
Plenty of those in these parts!
I believe that the remaining assembly plant in Galashields has had the chop. One of the best gillies in Kelso was a QA inspector at a Kelso plant.........he laughs at my soldering!
Old 24th September 2013, 09:02 PM   #56
bk856er is offline bk856er  United States
bk856er's Avatar
Current discussion in the equipment section....
BK
Old 24th September 2013, 11:41 PM   #57
Soundhappy's Avatar
Thanks i try this on pcb's
What your internal wire connection psu,audio for Mr Pass diy amps?
I am in preparation for F4, F5 and AlephJ soldering
Old 24th September 2013, 11:54 PM   #58
labjr is offline labjr  United States
The solder survey again?
I use Cardas Quad Eutectic solder. It makes a nice shiny bead. I guess it sounds good. 20 years ago I was using Wonder Solder. I love the way it flowed. Their new solder isn't the same.
Old 25th September 2013, 12:04 AM   #59
Russellc is offline Russellc  United States
I'm with you on that. I cringe not. Keep it hot, quick nice solders.
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre
Old 25th September 2013, 12:22 AM   #60
There are many choices, I ended up with 2 different Hakkos, A 936, and a 929.
Both have worked very reliably and I have no complaints. For my hobby purposes only uses, this is plenty.
Russellc
Best solder and wire for Pass diy amplifiers ?Hide this!Advertise here!
Magnet wire insulation that burns off in solder pot Circlotron Parts 5 17th September 2012 06:38 AM
Wire-Wrap vs. Solder phishead8 Equipment & Tools 12 24th May 2011 02:21 PM
How to solder ground wire to RCA Jack northernsky Construction Tips 13 23rd December 2009 08:27 AM
soldering iron temp and solder wire melting point. jarthel Parts 6 10th October 2006 03:12 PM
