Best solder and wire for Pass diy amplifiers ? - Page 3 - diyAudio
Old 23rd September 2013, 01:28 AM   #21
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by soundhappy View Post
Clean legs of resistors,caps,and transistors from little oxide before solder ?
That is not necessary, however it is very good technique.
Old 23rd September 2013, 02:40 AM   #22
Soundhappy's Avatar
Mr 6L6 on the line
At first why search for quality solder wire if legs be with some grey oxide dirt?
It is not always the case but sometimes yes.
Dear 6L6 what your diy point of vue about audio signal wire , psu wire,shielding
electromagnetic fild and solder in your Pass diy amps realisations?
For newbie your friendly F4,F5,AlephJ build guides is a truth reference
i liked very muchThanks
Old 23rd September 2013, 06:56 AM   #23
Stuey is offline Stuey  Australia
I've never had any problems just using plain 60/40 Jaycar solder (Australian electronics retailer OEM branded), even with reflowing 'vintage' solder tracks etc. it wets nicely and leaves a shiny joint. Sometimes I think people go overboard with this stuff. Maybe it's in the technique.
I do use a liquid flux from Cutter Electronics if repairing a track where the copper is oxidised.
Certainly you don't need expensive solder for new PCB's and clean wire and components.
Old 23rd September 2013, 07:45 AM   #24
Soundhappy's Avatar
Thanks Stuey
i see on Jaycar page this miracle product
Wire Glue 9ml - Jaycar Electronics
its funny maybe for prototype point to point connection
with few components like in
marvelous Zen amplifiers.
Well i am sceptical because solidity in time for this technique.
Ok my reason say quality classic solder is the way to go.
Maybe some diyer change my mind?
All solder , wire references for Pass diy pcb's F4,F5,AlephJ is welcome
make this aspect not neglected have fun
class A amplifiers with full range speakers
sings like angels in heaven
Old 23rd September 2013, 10:13 AM   #25
Soundhappy, off topic; my 16 year old daughter has just left Australia for a school trip to near you - Draguignan. Lucky girl! It certainly looks like a beautiful part of the world!
Back to solder...I believe Andrew recommends 63/37 solder because it is better for preventing cold joints (where the solder looks dull and doesn't form a good joint). It quickly solidifies when cooling, but 60/40 solder can be affected more by movement of the component before the solder hardens because it stays soft for longer.
I think others recommend silver content to enhance conductivity. So if you want the best, I guess these other solders are better than plain 60/40. But I am quite happy with the more common alloy.
Old 23rd September 2013, 10:41 AM   #26
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Stuey View Post
.... 63/37 solder because it is better for preventing cold joints (where the solder looks dull and doesn't form a good joint).
if it has low melting point and you exceed this just one bit it will look exactly like you say it wont ...
which is wrong
no
the best solder is what makes you a good solderer
sometimes we know very little, and sometimes we know too much
Old 23rd September 2013, 11:08 AM   #27
I'm only going by what I seem to remember others writing in support of their choices. I only posted again to prevent what you've just done; many on this forum just love to argue these things. Ah well.
What makes me a good solderer is that I'm highly skilled at it; it's not the solder.
Old 23rd September 2013, 11:24 AM   #28
I used to think I was a good solderer.
Until my landlady of 1980/1 saw some of my work.
She was a PCB assembler for a while in the Borders.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd September 2013, 11:29 AM   #29
Indeed; I'm only as good as I think I am...
Old 23rd September 2013, 11:31 AM   #30
Magnet wire insulation that burns off in solder pot Circlotron Parts 5 17th September 2012 07:38 AM
Wire-Wrap vs. Solder phishead8 Equipment & Tools 12 24th May 2011 03:21 PM
How to solder ground wire to RCA Jack northernsky Construction Tips 13 23rd December 2009 09:27 AM
soldering iron temp and solder wire melting point. jarthel Parts 6 10th October 2006 04:12 PM
Copyright 1999-2017 diyAudio
