Best solder and wire for Pass diy amplifiers ? - Page 13 - diyAudio
Old 29th September 2013, 02:01 AM   #121
Soundhappy's Avatar
Default Best solder and wire for Pass diy amplifiers
Originally Posted by 2 picoDumbs View Post
I'd rather build myself a Zen amp and contemplate different circuit ideas, and then hang out with ZM in the pub.
Have today make samples of this stranded wires from copper UTP cable
http://www.vishaypg.com/docs/11051/tn501.pdf
I try them in my amp prototype
L'Audiophile with schematics inside:
index
index
Thanks 2PicoDumbs
Have nice day!
class A amplifiers with full range speakers
sings like angels in heaven
Old 29th September 2013, 03:31 AM   #122
2 picoDumbs's Avatar
Works extremely well, especially for small signals eg input wires on Pearl 2
Old 30th September 2013, 02:11 PM   #123
jneutron's Avatar
I don't agree with everything JC says but I am not going to waste my time arguing with him.
With respect to soldering, nobody is arguing with him. He described a methodology for cleaning leads which he introduced to techs building some product to produce product which looks prettier. He also mentioned their surprise on the procedure he showed them.
I pointed out the problems that can result, why it could be a problem, and how to solve the look issue while maintaining metallurgical integrity.
No arguing. A simple discussion of chemistry, metallurgy, process control, and visual criteria for soldering.
BTW, most large companies, especially ones where critical equipment is made, will not allow an electronics designer to simply walk into the production line and modify how the techs perform their work. There is a very good reason for that. More cases than not, problems will result down the line, either short term, or long term.
jn
Old 30th September 2013, 10:33 PM   #124
I use a Met-Cal I bought on ebay. Special circuitry maintains tip temperature under load.
Any technology sufficiently advanced is indistinguishable from magic
Old 1st October 2013, 07:08 AM   #125
Calvin is offline Calvin  Germany
Calvin's Avatar
as for the initial Q of this thread:
Iīd say the solder and wire has to be marked īPASSedī.
Make, type and alloy donīt play any rule whatsoever ..... just let it pass.
jauu
Calvin
ps. no pun intended, just joking
Old 1st October 2013, 12:47 PM   #126
jneutron's Avatar
Originally Posted by flg View Post
Well, I can't really explain it
Enough said.
or wont
You just said you can't.
Two consecutive thoughts which are mutually exclusive.
more than the ego scientific f$%^&s
Your diatribe does not belong on an intelligent forum.
toodles, lemming.
jn
Old 1st October 2013, 05:05 PM   #127
flg is offline flg  United States
flg's Avatar
Electro magnetic interfearance will modulate/effect the signal. it will also likely become magnetized itself. It is supposed to be a ground sheild.
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Magnet wire insulation that burns off in solder pot Circlotron Parts 5 17th September 2012 06:38 AM
Wire-Wrap vs. Solder phishead8 Equipment & Tools 12 24th May 2011 02:21 PM
How to solder ground wire to RCA Jack northernsky Construction Tips 13 23rd December 2009 08:27 AM
soldering iron temp and solder wire melting point. jarthel Parts 6 10th October 2006 03:12 PM
Copyright Đ1999-2017 diyAudio
