continuity test psu
continuity test psu
Old 20th September 2013, 08:31 AM   #1
acumos is offline acumos  Italy
Default continuity test psu
Hi to all, I've finished populating the psu board v3. Now I'm testing it such as suggested in the guide. But if I use my dmm pointing on v+(-) and gnd it starts beeping but then stops and the value increases. Instead if I us the dmm at 20k ohm it displays 1k and increases slightly. ????? Help me.
Old 20th September 2013, 08:57 AM   #2
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
continuity test psu
your DVM is charging caps
that's normal
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th September 2013, 09:07 AM   #3
Chris Daly is offline Chris Daly  Australia
Hi Acumos
My thoughts are you are trying to measure resistance OHMS with DC voltage switched on. Most DMM's don't like this, and although they should not interfere with circuitry - its possible a cheaper DMM may do just that
Suggest you turn power off to then measure resistance. It would help to explain to us what the v3 psu board is, and attached to.
So switch power off before measuring resistance.
Cheers / Chris
Old 20th September 2013, 09:16 AM   #4
thank for your reply. The psu board v3 is the one sold by diyaudio store and I'm testing it unwired prior to connect it in my f5
Old 20th September 2013, 10:37 AM   #5
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
As Zen Mod stated, you are charging the caps when you connect your DVM. If you leave it connected long enough you should reach a steady state highish value (KOhms), depending on the caps used.
continuity test psuHide this!Advertise here!
New F5 build: Speaker positive showing continuity w/ground Hikari1 Pass Labs 15 5th May 2013 03:20 AM
test bench variable psu reapersdirge Equipment & Tools 5 13th December 2012 08:05 AM
PC PSU test nicoch58 Power Supplies 0 22nd November 2006 07:16 PM
How to test noise level of PSU? Sunsun22 Power Supplies 2 10th August 2006 01:48 AM
Chassis ground continuity? BlackDog Chip Amps 4 8th April 2004 03:45 AM
