whether or not increase current of front-end of alephx
Old 15th December 2003, 06:12 AM   #1
john-china is offline john-china
john-china's Avatar
Default whether or not increase current of front-end of alephx
i want to build 200w aleph-x. i collect a lot of irfp250 and irf9610.
i worry about too high input capacitance of irfp250 which will affect high frequency. so i want to increase the current of 9610 to 50ma ( how much is enough?). but i dont know whether or not
the modification of original sch is correct. my aleph-x will parallel
6 banks of irfp250 for each side.
if i increase the current , the volt of 392OHM resistor will not be about 4v , so i must resolve this problem , but i dont like capacitor-decouple. then i must keep the joint of 392OHM and irfp250 stay about -26v because rail to rail of my aleph-x is +30v to -30v. so negative supply of 9610 will be -26v-50ma*392OHM=
-45v. then i must separate power supply of 9610 from irfp250.
finally my aleph-x will use +-45v for front-end(irf9610) and +-30v for back-end(irfp250). can i do it so? will this aleph-x work?
i dont know if above modification is correct. pls tell me how to do.
maybe some simple way i dont know. give me more suggestion. thanks
Maybe i should not be lazy again
Old 15th December 2003, 08:54 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
You can crank up the front bias all you want in the front end.
Just adjust the resistors on the bias and off the Drains of the
diff pairs.
Old 16th December 2003, 02:05 AM   #3
john-china's Avatar
Default thank you Mr. Pass
this is really a good way to resolve my question.
so i will adjust 392(OHM) resistor to 80(OHM) for 50ma current of front-end. but i have another question. is 80(OHM) too low ?,
will this affect gain of diff pair of irf9610?
Old 16th December 2003, 02:21 AM   #4
The one and only
Yes, it will lower it.
whether or not increase current of front-end of alephxHide this!Advertise here!
parallel voltage regulators to increase current? troystg Solid State 22 4th September 2015 07:05 AM
LM4702:increase the output current,possible?? Leolabs Chip Amps 3 14th January 2008 04:11 PM
AlephX/XA & current hungry loudspeakers DarkOne Pass Labs 5 3rd November 2004 04:18 PM
AlephX with Current Feedback Netlist Pass Labs 17 19th January 2004 07:57 PM
increase the bias current of an opamp final stage herve Solid State 19 15th September 2003 12:29 PM
