Newbie needs advice: F5 Build parts
Old 6th September 2013, 10:06 PM   #11
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Originally Posted by Hikari1 View Post
You have read this? This will answer a lot of your questions.
http://www.diyaudio.com/.../build-gu...1.0.pdf‎
Please fix this link.
Old 6th September 2013, 10:40 PM   #12
brunk is offline brunk  United States
OK I have read the PDF, thanks for that by the way. However, I'm still confused on what value resistors for the snubber caps to use.
Here's the PSU caps I'll be using.
The snubber caps i chose were off the BOM .1uf 100VDC
The toroidal im using will be a SumR 400VA 115/230V Primary with 2x 18V secondaries.
I believe all i have left to figure out is what value snubber caps and resistors to use and what lengths of wire for PSU and signal then I'll be good to order. So anyone that can help with that would be much appreciated. Thanks fellas!
Old 6th September 2013, 11:13 PM   #13
Would anyone see a problem fitting this Antek 500VA toroidal in the deluxe 4U chassis? It's much cheaper than going with my previous choice.
Old 6th September 2013, 11:55 PM   #14
Hikari1 is offline Hikari1  United States
Should work. It's only .5 inch larger than the 400VA transformer used in the build guide.
Old 7th September 2013, 01:01 AM   #15
Andersonix's Avatar
Snubber caps and resistors are for Advanced Newbies only, so leave them out until you can tune their values to your transformer secondaries.
Old 7th September 2013, 01:15 AM   #16
AudioSan is offline AudioSan  Norway
Your caps seems spot on get 60.000uF+ pr rail
Old 7th September 2013, 01:18 AM   #17
but is it a snubber PSU?
you can also use a standar PSU with the PI filter. and a 2.2uF bypass cap pr rail. and 2.2Kohm 3W bleeder resistor.
Old 7th September 2013, 01:49 AM   #18
jdkJake is offline jdkJake  United States
For your jfets, spencer can be contacted through his storefront:
Store | FET Audio
-- jk --
Old 7th September 2013, 01:57 AM   #19
Hmm, I'm looking at the PDF link posted earlier on page 3 of the Universal PSU and it shows it can accommodate 4x 35mm caps on C12-C15, but when i go to the store and view the layout it appears it doesn't have those connectors for the 35mm. Could someone verify this as i'm quite confused lol. Does that mean I need to buy 8x 15,000uf 35mm caps instead of 4x 33000uf, or should i get 8x 30mm caps?
Do i install the bleeder resistor with the bypass cap, on the underside or something?
Thanks again for the support.
Old 7th September 2013, 01:59 AM   #20
Store | FET Audio
Thanks for the link, I'll keep it for reference just in case mine come out to be fakes even though the seller said they are originals.
Newbie needs advice: F5 Build partsHide this!Advertise here!
Parts kit for F5? uzernaam Pass Labs 17 23rd November 2014 08:05 AM
Newbie advice - Phono Preamp/1st electronics build chirs Tubes / Valves 7 30th May 2013 10:30 PM
FS: F5 amp parts for build mravlca Swap Meet 9 30th January 2013 10:31 AM
FS: Parts for F5 build Milkduds Swap Meet 2 5th July 2011 04:33 PM
F5 Parts List enzedone Pass Labs 2 22nd August 2008 12:15 AM
