What DAC do you use with F Amp. - diyAudio
Old 2nd September 2013, 04:55 PM   #1
oon_the_kid's Avatar
Default What DAC do you use with F Amp.
The basic philosophy of the F amp is simplicity and minimum amount of stages. It doesn't make any sense if you add a couple of of op amp along the way. So which DAC do you use... and how does it implement its output stage...
Oon
Old 2nd September 2013, 05:21 PM   #2
6L6 is offline 6L6  United States
6L6's Avatar
It also doesn't make any sense to have a source component before that doesn't work properly, and all digital sources will need IC's and opamps...
That said, the Odac is wonderful.
Old 2nd September 2013, 06:02 PM   #3
ICs yes... but not opamps. the D1 for example doesn't have any. There are discrete output.. transformer output, and direct output...
Oon
Sent from my Tab 7.2 using Tapatalk 2
Old 2nd September 2013, 06:20 PM   #4
different approach, different sound, for different people.
i've been messing with tda1543 passive output for months now, trying many caps then transformers. will try actives now starting with ad844 as i find passive output ultimately leaves me hungry.
that being said, i still think r2r or bust
Old 3rd September 2013, 02:29 AM   #5
Hi PreSapians,
I meant op amp is not a must, there are alternatives...
I had a TDA1541 at one time too, driving a resistor direct. I too felt it was a bit lethargic. There is no sense of ummph. My guess is the chip itself wants to see a virtual ground at the output, but the voltage will swing because of the passive resistor. Output level tends to be low because there is a limit tot he voltage swing.
You should consider the Pass D1 output stage for your I-V conversion. I think it is probably one of the better implementation for I-V conversion. Better than a op amp I-V converter. Search around this forum for the Pass D1 service manual.
Well the reason, I sound a bit negative towards op amp, is the very nature of op-amp is directly opposite the philosophy of the F series amps. F amps are charaterised by high linearity open loop and minimal or no global feedback with minimal active stages. Op-amps are by their nature, high gain, low linearity open loop and massive global feedback and has about 4 active stages. So putting them in the same bed seems counter intuitive.
However even opamp outputs have varities to them. there are those used with I-V conversion, and/or differential amping filtering and output buffer. There are some with a single op amp stage just for differential output as well some with 4 stages of op amp for i-v conversion, differential output followed by a low pass filter and finally a buffer. This will give it something like 16 transistor gain stages.
Theoretically, it would be possible to power your amp with the DAC chip directly, given the theoretical minimum of 1 transistor (example, F2, Aleph, SIT) in between the DAC chip and the speaker.
However the proof is in the pudding, so it will be worthwhile to hear listening impressions of your DACs with your F-amp.
As for myself, I have not gotten around to rotating different DACs with my F2j yet. So not really qualified to comment.
Oon
Old 3rd September 2013, 08:31 PM   #6
WalterW is offline WalterW  Netherlands
Oon
Good questions, that's exactly what's on my mind, lately.
Building the best possible DAC in First Watt style.... (nice project for the long upcoming winter)
Hoping on a lot of suggestions here ...
Walter
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6
Old 3rd September 2013, 10:24 PM   #7
i use fet audio's FDA2 DAC. the output stage is build around the good old D1. only not balanced. with AD1955 DAC chip.
Old 5th September 2013, 12:22 PM   #8
That is an interesting dac. Looks good.
Old 5th September 2013, 12:44 PM   #9
it's a very good DAC. i will be buying one more to have as internal DAC in my CD-pro transport.
Old 5th September 2013, 01:20 PM   #10
billyk is offline billyk  United States
billyk's Avatar
I will for the time being go with the Subbu DAC V3. Inexpensive and simple, basically a ES9023 DAC and a WM8804 receiver. I am hoping there will be an I2S version as I have a nice setup waiting for that too. Looking to upgrade to an ES9018 DAC in the future but that gets expensive and the F5T kinda drained my budget for now!
cs8414 & wm8740 dac (one dac chip) sparkle Digital Line Level 28 28th March 2012 02:10 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 08:03 AM
MICROMEGA Drive 3 & DAC Faulty & MODS eldarvanyar Digital Source 7 28th April 2010 08:30 PM
Rotel 855 PICS, dac & opamp question for newbie... psonic Digital Line Level 71 9th April 2010 12:59 AM
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 06:10 PM
Copyright 1999-2017 diyAudio
