Aleph J illustrated build guide - Page 66 - diyAudio
Old 27th February 2014, 03:10 PM   #651
brunk is offline brunk  United States
Originally Posted by 6L6 View Post
Also try buzzforb. I've used both guys, they are great! Hannes, (h_a) may have complete transistor kits as well.
Do the MOSFETs require matching for the Aleph J?
Old 27th February 2014, 03:15 PM   #652
6L6 is offline 6L6  United States
6L6's Avatar
Yes.
However, you only need match the Mosfets that share current - Meaning you may use a pair that has the same Vgs for the Current source fets (Q5, Q6) and a pair that has a different Vgs for the power output (Q7, Q8).
Yes, a matched Quad per channel, or a matched Octet for a stereo amp is more convenient, it isn't necessary.
Old 27th February 2014, 03:21 PM   #653
Yes.
OK thanks. I'm assuming the same goes for F4 too?
Old 27th February 2014, 03:27 PM   #654
6L6's Avatar
Yes, the N must match the N, and the P match the P, but no need to match N to the P.
Old 27th February 2014, 03:35 PM   #655
Thanks again
Old 27th February 2014, 04:44 PM   #656
badtoby is offline badtoby  United States
Buzzforb is out of them.
Old 27th February 2014, 04:46 PM   #657
Bummer. If you can let me know where you're able to source them, I would appreciate it
Old 27th February 2014, 04:56 PM   #658
Will do
Old 4th March 2014, 09:06 PM   #659
Bones13 is offline Bones13  United States
Techie Wanabe
Bones13's Avatar
I can only encourage you all to try the Aleph J in full balanced mode. - Wow.
My blue jeans cables arrived finally.
W4S STP-SE - DIY Aleph J - Zu Audio Druid V + Undertone
(Analog) VPI Scout Sig - K&K Audio Maxxed Phono (Digital) microRendu - Bryston BDA-3
Old 8th March 2014, 03:11 PM   #660
Seavan is offline Seavan  United States
Can you help me with what input I should ground for RCA? Is it IN- that goes to ground and IN+ is an actual input? Thank you!
An illustrated guide to building an F5 6L6 Pass Labs 967 23rd April 2017 08:10 PM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
An illustrated guide for Aleph 60 builders PKI Pass Labs 58 12th October 2013 07:13 PM
Aleph J Stuffing guide ? thor61 Pass Labs 2 4th September 2011 08:02 PM
My first step by step LM3886 illustrated build kgb_m3 Chip Amps 19 17th February 2010 04:46 PM
Copyright 1999-2017 diyAudio
