Aleph J illustrated build guide
Old 4th January 2018, 01:52 AM   #2371
Eslheadphone is offline Eslheadphone  United States
I did notice a change in VGS as the FET heated up on the jig. The goal was to take all the FETS to be matched safely to the same temperature they would see in the amplifier. As I was in no hurry I found 5 minutes worked just fine. I did have two different batches so my yeild was lower than if they had been from the same lot. After mounting the FETS to the Heatsink, I checked the resistance between all the Drain leads of the Fets to chassis ground.
Old 4th January 2018, 07:13 PM   #2372
Eric is offline Eric  United States
Eric's Avatar
Yep, they do change as they heat up for sure!
But, once you find ones that track one another at the same rate for some fixed voltage level, they also seem to follow one another for other voltages and currents as well. Thus, matching at ANY reasonable voltage and current is sufficient. I've matched over a hundred mosfets for various amps and haven't found any that don't follow this rule.
Once they match - they are a match!
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based DCB1 + BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Old 10th January 2018, 09:21 PM   #2373
dbis is offline dbis  United States
Hey Everybody,
I hope this is the right thread to post this in. If not please let me know.
After building the Amp Camp monoblocks, an F5, a Sony VFET DIY, I have just finished the right channel for an Aleph J. Everything seemed go smoothly and it sounds great. I have the bias at 400mVdc and DC offset adjusted to zero. Temp on my heatsink after one hour hovers at about 42-43°C.
That said there are a few things that happened along the way that seemed a little odd to me:
1. Before powering up I double checked the board and the components to make sure I got them all in the right place. I had set the R27 pot to 68k ohms per the Illustrated build guide—thanks 6L6!— before soldering but once soldered in I double checked it with the handy pads on each side of the pot. When I first put the probes on the resistance was very low but then it started slowly climbing and after about 20 sec or so leveled off and stopped at 68k. This may be normal but I hadn’t seen it before.
2. When I first powered the Aleph J board on the bias, with R27 set at 68k, was quite high, around 650mVdc. I had to turn the multi-turn pot quite a few turns to get it down to 350mV. Right now when I measure the R27 pot resistance on the board it’s at about 16k. Does that sound right?
2. I always start new circuits for the first time with a dim bulb setup, 100 watt. Usually for a split second the bulb glows very bright and then gets really dim, almost out. However, when I first powered up the Aleph J, as usual, it got really bright for the spilt second and then got dimmer but not as dim as on my other projects, probably about 2/3 as bright. I biased it to around 350 mV, kept an eye on the temp, left it for 30mn then biased to 400mVdc and set the dc offset to zero. I did all this with the input shorted. Then tried some music with an old speaker and it sounded fine.
3. When I turned the amp off after an hour the PSU red, positive LED went dim right away while the green, negative rail one stayed quite bright for several minutes. I disconnected the Alpha J board and turned the unloaded PSU on and off again. Both LEDs stayed lit for several minutes. Kind of strange.
4. When I turn the amp off there’s a slight" fa-thump". From several posts here it looks like this is normal with the Aleph J and actually I have more of a turn-off thump with my AC monoblocks. Neither my F5 nor VFET has turn-on or turn-off noise though. However, the turn-off noise worries me just a bit because I first noticed it when I did something I normally don’t do: turn the amp off before turning the music off and turning the volume down. When I did that I was surprised by this sort of crackling “squEEEALch”. Tired it again with the music turned off, so no signal, and got the more familiar low “fa-thump”. BTW, my ACA’s have a louder one syllable "THUMP” but the Aleph J is definitely a two syllable “fa” then “thump” but a lot softer than the ACA’s. I tried powering down by using a power strip instead of the PEM switch but the noise was still there. If I don’t that with the ACA’s there’s no thump.
I kind of think all these things might have the same origin.
I am attaching a photos of the PSU and the Aleph J PCB . I took the PSU photo after I had disconnected the rails from the Aleph J board. In the meantime I'm building the left channel board so it might be interesting to see if the same thing happens or not.
I would be very appreciative for any advice. And, as always, thanks to Mr Pass, Diyaudio.com, 6L6 and all you guys for making this all possible.
Dan
Old 10th January 2018, 10:04 PM   #2374
6L6 is offline 6L6  United States
6L6's Avatar
1) Bias is not just a function of the pot, it’s the pot and the Vgs of the particular mosfets you have. It’s going to vary, hence why its a pot.
2) see No.1
2 a ) Alephs pull a lot of current. They get hot. Hence the bulb staying a bit lit after the inrush.
3) The circuit discharges the positive rail a lot faster than the negative. That’s normal for this amp
4) See no.3
Old 10th January 2018, 10:10 PM   #2375
Wow! That was quick. Thanks 6L6. So it sounds like my Aleph J is fine Thanks again.
Old 11th January 2018, 04:58 AM   #2376
I brought my J on a Variac and turned the bias pot down as I brought the line voltage up, and as you experienced I turned quite a few turns. I used the Diy speaker protector and now my amp is tump-less. This is a really really nice sounding amp. Well worth the trouble to build.
Old 11th January 2018, 03:19 PM   #2377
Hi Eslheadphone,
Thanks for the info. I actually have a speaker protection board I’ll add once I get both channels done. The turn off thump really isn’t very loud at all; I’d just never run into things like the rails discharging like that before. I was relieved to find out that’s normal.
Thanks,
Dan
Old 15th January 2018, 01:24 AM   #2378
nuconz is offline nuconz  United States
Thumbs up what a wonderful guide/tutorial!
Originally Posted by 6L6 View Post
An illustrated guide to building the Aleph J
This is a guide to building the Nelson Pass / Firstwatt 'Aleph J' amplifier.
You are free to comment or question.
this is a wonderful guide/tutorial!
the bottom line - how much does building this amp cost?
thanks.
Old 15th January 2018, 03:09 AM   #2379
6L6's Avatar
$700 give or take, depending on how much you have laying around and/or can scrounge or fabricate.
If you buy all the stuff available from the diyAudio store and all fresh parts from Mouser or Digi-Key I bet you can be pretty close to $700, maybe a tad under.
Old 15th January 2018, 12:16 PM   #2380
thanks. is it worth the $700?
Aleph J illustrated build guideHide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 999 30th May 2018 10:33 PM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
An illustrated guide for Aleph 60 builders PKI Pass Labs 58 12th October 2013 07:13 PM
Aleph J Stuffing guide ? thor61 Pass Labs 2 4th September 2011 08:02 PM
My first step by step LM3886 illustrated build kgb_m3 Chip Amps 19 17th February 2010 04:46 PM
