Aleph J illustrated build guide
Old 1st September 2013, 11:45 PM   #11
Bones13 is offline Bones13  United States
Techie Wanabe
Bones13's Avatar
Thanks, it (the schematic) opened in a new window fine!
W4S STP-SE - DIY Aleph J - Zu Audio Druid V + Undertone
(Analog) VPI Scout Sig - K&K Audio Maxxed Phono (Digital) microRendu - Bryston BDA-3
Old 2nd September 2013, 12:14 PM   #12
ticktock is offline ticktock  Scotland
ticktock's Avatar
Hope I may add some suggestions here.
If the lead spacing of C1 allows for 27.5 mm (to me it seems to) you should consider
this film-foil type instead of the cheaper metallized poly, also available at Mouser:
Mouser 505-FKP41.0/400/10
For C6 & C7 you might consider these (same 5 mm lead spacing as Wima MKP):
Mouser 505-FKP2.022/100/5
Mouser 505-FKP20.033/63/2.5
Where a wider lead spacing is applicable FKP3 is an even better choice.
For C5 I need to say, that at least many using the PCBs of an earlier German group buy
had much better results with 10 pF - both audibly and measured. I have to admit this
might differ depending on the PCB design.
thanks
Blaue Leuchtdioden machen blöd. (hb)
sent from NSA monitored device
Old 3rd September 2013, 08:22 PM   #13
6L6 is offline 6L6  United States
6L6's Avatar
Added chassis assembly section.
Old 3rd September 2013, 08:26 PM   #14
CanAm Man is offline CanAm Man  United States
Jim.....as normal, your photography is outstanding, as are your assembly guides!
Old 3rd September 2013, 08:28 PM   #15
6L6's Avatar
Thanks, I appreciate it!
Old 3rd September 2013, 09:05 PM   #16
1MOR is offline 1MOR  United States
Thanks Jim, you make it look way toooooooooooo easy!
Old 3rd September 2013, 10:09 PM   #17
henryve is offline henryve  South Africa
henryve's Avatar
I am still waiting for my boards and you guys are all having fun. My boards apparently left the US at Los Angeles on the 21st of August and I still don't have them. Damn, sometimes staying in dark corners of the world bites.
Must .. be .. patient.
Old 4th September 2013, 02:11 AM   #18
sakellogg is offline sakellogg  United States
sakellogg's Avatar
they are wonderful youll lovethem.
side note: i got mine already nanana booboo!
couldnt help myself sorry.
I'm not crazy, my mother had me tested
Old 4th September 2013, 11:13 AM   #19
bnorrish is offline bnorrish  United States
bnorrish's Avatar
2 day delivery on the boards to Boston!
Old 5th September 2013, 02:49 AM   #20
Techie Wanabe
Bones13's Avatar
Whetted my FirstWatt appetite with the ACA. Such good sound from the simple amp.
Pawing through my left over boxes yielded a quad of Silmic II 220 mF 100v caps. They look to fit well on the board. I also found 4 nice 1 uF film caps from a pair of speaker crossovers that were upgraded. They are about 1 inch long, 1/4 inch diameter. Will they be better or worse bypass caps with the longer leads that will be needed to hook it up? It would be silly to use them, and have them be markedly worse due to longer connections. Actually, I'll put those at C1, and stick with the Wima bypass caps.
Got my boards and 500u case. AnTek Transformer was shipped this week. JFets are here, output transistors from Buzzforb en route. Finish up my Mouser BOM, and I'll be cooking.
Aleph J illustrated build guideHide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 999 30th May 2018 10:33 PM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
An illustrated guide for Aleph 60 builders PKI Pass Labs 58 12th October 2013 07:13 PM
Aleph J Stuffing guide ? thor61 Pass Labs 2 4th September 2011 08:02 PM
My first step by step LM3886 illustrated build kgb_m3 Chip Amps 19 17th February 2010 04:46 PM
