Old 12th December 2003, 11:06 PM   #1
MEGA-amp's Avatar
Question aleph 2
Hey everybody,
I finally decided what to build after reading countless posts and studying, an Aleph 2. And I highly recommend reading Teach Yourself Electricity and Electronics by Stan Gibilisco, very helpful.
I am purchasing 4 pcs 10"X18" 1/2" baseplate w/4" fins for alpeh 2 monoblocks. I plan on mounting KRISTIJAN's FET boards squared and centered on the sink, 1 on each sink of course. I'm not great with formulas, so I am wondering if this size heatsink is sufficient? I am assuming it is.
Also planning on purchasing Plitron's 1500VA 38v sec transformers for each block. I will be using a Pi filter per KRISTIJAN's PS schematic. What value should I use for the coil? I've seen people using 3.9mh coils with that secondary voltage, just wondering if i'm the ballpark.
Many thanks,
John
Old 13th December 2003, 12:03 AM   #2
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
heatsinks sound big enough.
FETS mounted in the middle is ideal.
1500 VA toroids are fine... so would 1000 VA, up to you. i think the
original had 750VA? (i think i remember reading that somewhere)
38 volt secondaries are fine.
i used 2mH coils in my Aleph 2... 4mH would be fine too. Kristijan's
PSU shematic is a good one to follow. Check out mcmelectronics.com
for them.
sounds like you've done your homework! Good Luck, you will not
be disappointed
Old 13th December 2003, 12:14 AM   #3
I think 2mH should be ok.
If you haven't used the coil 38VAC might be a bit too high,but with coil should be allright.
1500VA should be just fine.
I know (from good source) that original Aleph 4 uses 2KVA transformer,so I think Aleph 2 monoblock uses at least 1,5KVA,and I wouldn't be supriced if it's more.
Good Luck with your project!
Bartek
Old 13th December 2003, 04:49 AM   #4
moe29's Avatar
Aleph 4 is a stereo Aleph 2 in one chassis, thus 2KVA transformer.
1K VA is plenty for an Aleph 2. More is overkill, but that's up to
you and your wallet.
Old 13th December 2003, 09:14 AM   #5
Not exactly.
Old 13th December 2003, 12:36 PM   #6
grataku is offline grataku  United States
This is an old subject but with the different AC freq the low pass should be a little bit different betwen US and EU. In practice 4mH in EU is equivalent to 2mH in the US.
Old 13th December 2003, 12:39 PM   #7
moe29's Avatar
Quote from the service manual:
The Aleph 4 is a stereo 100 watt audio power amplifier which
operates in single-ended class A mode.
Old 13th December 2003, 05:03 PM   #8
I meant that Aleph 4 is not exactly two Aleph 2 in one chassis.
The power requirements might be a little bit diffrent becouse of the small diffrances in schematics.
Bartek
Old 5th January 2004, 01:15 AM   #9
True, the Aleph 4 and the Aleph 2 were both 100W amps, but the Aleph 2 ran higher bias. All things being equal, more bias is good, so the nod goes to the Aleph 2.
Grey
Old 5th January 2004, 01:44 AM   #10
Brian Donaldson's Avatar
And the power supply voltage is totally non critical. I've ran mine all the way from +- 25V to +- 65v with very little sound difference (except power output) I had to tweak the bias back (I have a pot)a bit to keep temp down at 65v.
The amps sounded more open with the higher rails an lower bias. Best compromise was around 4.5A and +- 50V
I strongly considered putting my 22A variac in an enclosure and using it as a soft start and heat adjustment for non critical listening so I could choose not to put almost 1 kw of heat into my balmy Houston livingroom.
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 13 27th April 2012 02:13 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.13487 seconds (70.01% PHP - 29.99% MySQL) with 10 queries
