How hot can I bias my F5? - Page 7 - diyAudio
Old 18th October 2013, 03:16 AM   #61
KevinHeem's Avatar
Default Now we're cooking
I turned the bias on my F5 up to .7V also. Everything seems fuller and richer. Of course i did have two Dragons Milks (New Holland Brewing). They are full and rich also, so it could be the beer talking.
Old 21st October 2013, 02:23 AM   #62
crcook is offline crcook  United States
Hmm. Got me thinking about upping the bias. On my second glass of a killer Zin from Trader Joes....$10/bottle. Maybe 0.7volts is OK....
Old 21st October 2013, 02:50 AM   #63
KevinHeem's Avatar
I'm using the the big 5U chassis. Be careful that you don't get too hot in the 4U chassis. What is the temperature of your heatsinks?
Old 21st October 2013, 04:17 AM   #64
Running about .59V at the .47 ohm resistors, i have 20 deg C over ambient at the heatsinks (using remote laser scanner). That is with the amp running music for about 3 hours. I will up it a bit to .65V tomorrow while monitoring the temp. I do not want to risk blowing anything up and Nelson recommended the bias current at 1.3 amps or about .6V at the bias test point.
Also, I am running only 20v DC vs the 23v most have. Using a 16V transformer, as the 18v are out of stock. Not sure how much that affects things.
Old 21st October 2013, 04:49 AM   #65
Hikari1 is offline Hikari1  United States
With the 5U chassis I am at .760 (1.6Aish). I can hold my hand on the heatsink forever. I have small kids and a curious cat so I think I will stop at 1.6A. And I am getting sick of having test leads sticking out of the amp all the time. One thing is sure though...every bump in bias (I've gone from .5V to .6V to .7V and now .76V) has sounded better with more dynamics, more control and a more precise soundstage.
I am building a BA-3 based preamp now...hopefully it will best the Jfet Boz. Next I am looking at maybe Toshiba Mosfets for the F5 or finding a way to mount the rectifiers directly to the caps upside-down with a heatsink on top. Maybe CLC filering. Also, bypassing the power caps with some 10UF polys was a good move. It never ends...
Old 21st October 2013, 03:12 PM   #66
noSmoking's Avatar
Hi CRCook,
Here is the man himself's explanation on what it happening to the F5 and what you can do and not do,lol
Try this link and see if it will help! http://www.firstwatt.com/pdf/art_f5_turbo.pdf
Happy Listening!
NS
Old 21st October 2013, 03:23 PM   #67
Thanks for the link. I was looking for followup from F5 users, slowly slogging through diy posts.
Old 21st October 2013, 06:26 PM   #68
noSmoking's Avatar
Hi crcook,
I have 2 f5's what do you want to know?
If you really want to know how hot you can run them it goes like this ,If you have big heat sinks,you can run the bias up till the heatsinks get up to 50 C,then you keep a eye on the transformer because if it's not big enough it will get hot and most of the time starts buzzing,Fans will help the transformer and the heatsinks,alot of folks run .6a and play music,some run 2.6A too ,It's just how much hardware you have and how well you can get rid of the heat,lol. I guess a balancing act so to speak!
I am running water cooled sinks ,I ran up to 3 amps bias but backed off to 1.5 my trans former started getting warm,My F5 sounds good there ,so I am happy,I also have 2 F5c they give the bass a new name ,lol. I read all the F5xxx threads 2 ,,,takes a while,(weeks)might double up your Jfets too! If you have a variact ,try dropping the rails to 18v and reset your bias and then your DC offset,
A different sound there also and putting 5 R in the J74 changes things a bit too!Better curve tracking,
Have fun I do! Best to you!
NS
Old 21st October 2013, 08:16 PM   #69
Thanks for the info. I am running a 18vAC transformer, and biasing it now at .625v at the resistors. Sounds great so far, so I probably will not push it farther.
I may go up a bit on the transformer voltage to 20v (when available from Antec) or 22v. Not sure.
Old 21st October 2013, 08:39 PM   #70
noSmoking's Avatar
If it's loud enough ,it's good to go!!!!
Good luck!
NS
Sanken S-40W bias problem/getting hot, any ideas? flyingtele Solid State 2 19th December 2012 10:38 AM
How Hot Is My F5? dantwomey Pass Labs 75 25th April 2012 11:43 AM
Runaway bias on Hot Rod Deville EatMoreArt Instruments and Amps 6 6th March 2009 12:43 AM
bias amp while hot or cold? nicksmurf Solid State 5 28th June 2003 07:56 AM
Copyright 1999-2017 diyAudio
