heat transfer of MOSFET to heatsink
Old 4th August 2013, 01:38 PM   #1
jdg123 is offline jdg123  United States
jdg123's Avatar
Default heat transfer of MOSFET to heatsink
Please help me beat the heat for my first Pass Labs DIY...
In the BOM for Aleph J there is no mention of a paste or pad for attaching items to heatsinks. I just need a recommendation please.
Thanks!
Old 4th August 2013, 01:50 PM   #2
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
search for "mica and goop" thread
no need for beating a dead horse
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 4th August 2013, 02:09 PM   #3
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Mica or silicon insulator and "goop" which is thermal transfer compound - otherwise known as white s**t. If you opt for the grey soft insulator you wont need any goop.
Old 4th August 2013, 03:15 PM   #4
6L6 is offline 6L6  United States
6L6's Avatar
The DIYaudio store sells red Keratherm in the proper size - these are the amongst best available goop-less insulators you can get.
10 Keratherm® Red Insulators - Parts
If you don't want to wait, you need a pad designed for TO-247 and/or TO-3P package fets, and are looking for a low thermal impedance.
The search engines at Mouser and Digi-key both have a fantastically hard time with this...
So here you are - http://www.mouser.com/ProductDetail/...aI9mlusI07Y%3d
This is the new Bergquist A2000 material, which looks to be incredible good.
Old 4th August 2013, 03:49 PM   #5
jdg123's Avatar
Default great help!
Thank you for the excellent pointers!!!
Old 4th August 2013, 03:54 PM   #6
Please do read up on "goop". It's not there to help the thermal transfer, well not in massive quantities anyway. The aim is to get the "devices" to sit as flat as possible on the heatsink so that heat can flow. If the MOSFET was PERFECTLY flat and the heatsink was PERFECTLY flat there would be no requirement for goop. In reality the two mounting surfaces are anything but flat. The goop is only there to fill in the irregularities between the two surfaces.
Old 4th August 2013, 09:40 PM   #7
Triodethom is offline Triodethom  United States
Triodethom's Avatar
A sheet of glass and some 2000 grit paper to polish the surfaces are how cpu get mated to heat sinks and then they still use silver goop. Well at least the hard core ones do this for heat transfer.
Old 4th August 2013, 09:45 PM   #8
Triodethom's Avatar
How about the
SPA2000-0.015-00-58 it about 1/2 the price .
Old 4th August 2013, 10:25 PM   #9
6L6's Avatar
It's too small for a TO-247.
Why are you speaking so largely?
Old 5th August 2013, 02:40 PM   #10
Triodethom's Avatar
Sorry about that it the past and copy I used did not mean to be rude.
heat transfer of MOSFET to heatsinkHide this!Advertise here!
Improving heat transfer of ICs uncle_leon Chip Amps 64 15th July 2011 10:36 AM
heatsink thermal transfer GeeVee Solid State 4 29th September 2009 01:10 PM
Coping with amp box heat (not heatsink sizing) cfcubed Pass Labs 5 23rd July 2008 04:59 PM
Heat transfer sompound and mica , silpads etc dhole Pass Labs 1 29th April 2005 04:45 PM
Is solder a good heat transfer medium? leadbelly Parts 3 11th March 2004 03:33 AM
