Old 9th December 2003, 09:58 PM   #1
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
Default got some heatsinks! which aleph to build?
hey everyone. i was at a surplus shop today and i picked up some heatsinks cheap ($20). they are in great condition, just with a few holes. i found the profile from AAVID. here it is:
http://www.aavidthermalloy.com/bin/e...3&airflow=57.2
if that link doesnt work, its product #66880.
Its thermal resistance is 1.18 @ 3" length. I have two 13.25" lengths. I want to do a stereo amp either for rear channels or for bi-amping my fronts. could i pull off a stereo aleph 5?
Old 10th December 2003, 03:54 AM   #2
cowanrg's Avatar
i cant belive no one in here knows...
Old 10th December 2003, 04:31 AM   #3
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
7" x 13" ?? I'd say a pair of those could do a monoblock.
4 for stereo.
besides you've got other projects to finish first!!
Old 10th December 2003, 04:36 AM   #4
elizard is offline elizard  Canada
Send a message via MSN to elizard
i got some VERY similar (if not exact) .. i got 4
i'm goin for an aleph 5 (2/chan)
Old 10th December 2003, 04:38 AM   #5
Send a message via AIM to ScottRHinson
Default Re: got some heatsinks! which aleph to build?
Are they anodized? The web applet gives a thermal impedance of a 13.25" length at .56 C/W. I'm pretty sure that's for the unfinished aluminum heatsink as Rod Elliot's spreadsheet comes up with pretty much the same number.
You really don't want the temp of the sink to be much over 50C (you can, but then the parts are running very hot, and it will HURT to touch it, I know it's time to stop steaming the milk for my morning Latte when I can't hold the pitcher...)
So, assuming at 25C (77F) room, that's a rise of roughly 25C. 25/.56 = 44 watts dissipation. No, an Aleph 5 will not fit on that heatsink without serious fan cooling.
If the sink is nicely black anodized the thermal impedance may be as low as .25 C/W 25/.25 = 100 Watts...and an Aleph 5 will still not work without fan cooling.
Scott
Old 10th December 2003, 04:46 AM   #6
Mine are anodized (not sure of his).
I figure with 2 anodized, i'd get around .12-.15 with 2 of them, so 4 is enough for both channels ..
Old 10th December 2003, 05:30 AM   #7
cowanrg's Avatar
wow, i wasnt aware an aleph 5 had THAT much heat! would i be fine then with an aleph 3 in stereo? i was hoping to get a bit more power out of this then just 60 watts into 4 ohms, but it looks like thats the most i could get
oh, and yes, they are anodized black.
Old 10th December 2003, 09:15 AM   #8
Tubie Noobie
The size of those heat sinks sound similar to mine. My Sinks are 9 x 12. I operate at 1.8 amps bias per channel. Quite warm but can hold it for about 20 seconds. If it gets too hot put a small fan on it, change the bias, or change the number of fets, after all its DIY.
The driver circuits are about the same.
Old 10th December 2003, 01:14 PM   #9
Thats all *if* you want it convenction cooled. Fan cooling helps A LOT. I have some truely large heatsinks 15.5X19x1.5 with 40 cooling fins running the long dimension, 23 pounds each. I purchased them before I found Rod Elliot's spread sheet. (It's pretty accurate I must say.)
I thought they would work for me, but I decided to test them before I started drilling. I bought 26 1.5K Ohm 25Watt Aluminim cast resistors from the local surplus place, which if you wire in parallel and plug into the wall (in the US) is good for ~250 watts of dissipation about that of an Aleph 5 if I remember correctly. I clamped them to said heatsink (I have 3) and off I went.
It took about 3 hours to reach thermal equalibrium, which was a temp rise of 42.5 degrees c, or .17 C/W each. Way too hot. By Rods spreadsheet if I get them anodized they will be .09 C/W, but it will be hard to realize that in real life I bet.
Now, I turned on the ceiling fan to see how much a little bit of air cooling would help was enlightening to say the least. Temp rise of the sink was 17C, for a thermal impedance of .068 C/W, and that was with general air movement, nothing directed at the heat sink itself.
Now, 250 W without the fan on generated quite a chimney (spelling?) effect on the sink, if you held your hand over it you could feel the hot air coming up off of the sinks.
When this was all said and done (and the temp of the room was 5 degrees hotter) I decided that an Aleph 3 on smaller sinks, fan cooled was for me..and I'd save the big sinks for a big AB biased amp where their long time constants could be put to use.
I also dug out my old power electronics college text to check out the equations that govern heatsinks. It turns out there are some terms in the denominator of the impedance equation that are a power of 4...that's N^4. Heatsinks have to get quite big to get a lower impedance and they must get bigger wayyyyy faster than you think.
Scott
Old 10th December 2003, 02:33 PM   #10
moe29's Avatar
Scott,
sounds like you are describing the Chatham heatsink. I use two
of those for 1 channel of Aleph 2... and they get toasty! I remember
thinking that it was overkill to use 2 sinks per channel, but it
actually worked out quite well. So the rule of thumb is, when in
doubt, double it! - you can never have too much heatsink. I think
the Chatham heatsink suffers because it's cooling fins are to small
at 1.5"... i bet it would help a lot if they were 3".
m.
Ready to build ZV9 - Need heatsinks! Paul Ebert Pass Labs 15 29th April 2006 08:38 AM
Aleph 5 heatsinks tonistefanovski Pass Labs 4 26th July 2005 06:32 AM
Heatsinks for Aleph 5 tobias_svensk Pass Labs 2 15th February 2004 04:08 AM
New Aleph 4 - heatsinks anyone? apassgear Pass Labs 43 10th December 2002 08:44 PM
heatsinks for aleph 2. BrianGT Pass Labs 12 12th March 2002 06:59 PM
Page generated in 0.12925 seconds (81.86% PHP - 18.14% MySQL) with 11 queries
