Well Wooo hoooo!
After extensive web research and data sheet reviews, I find that the 2SJ75 and K240 I have are actually 2 each, matched of the 2SJ74 and K170 in a common metal housing. If I get stuck I could take these apart, although it would be a shame to ruin a perfectly good matched pair of these....
I'll keep looking for the discrete 2SJ74 and K170.
Cheers
Paul
Cheers
Paul
Okay,
So I have reread all 2 lbs of paper and thought about your recommendations....and it looks like the F5 and the Aleph J to start with. I coincidentally just rx'd and email stating that DIY now has cct brds available for the F5 so I checked them out...and they are for V2 not V3 like I wanted to build...rats! Has anyone done artwork/Gerbers for V3? I will search when I get home. I see the Aleph J brds are available which is great! I haven't found an actual A J builders thread, or even an article from NP specifically for the Aleph J, however I am sure it is out there but I just haven't spent enough time looking. Still out camping.
Now, for semi's, I have lot's of 2SJ175, 2SK240, 2SJ75, 2SK389 and 2SJ109 from previous projects, but no 2SJ74 or 2SK170's. Darn! Anyone have some extras you want to sell or know of sources? I also have some power MOSFETs from previous projects but again, will have to find them in all the boxes of stuff when I get home.
Cheers for now and THANKS all!
Paul
If you already have some 2sj109bl its worth to take a look at this homepage
AlephWiki : Aleph J
-But its all in german-
They have a pdf for etching the board by yourself and the pcbs are laid out for the 2sj109
I`ve build my J with the the layouts from there works pretty well.
Heading there tomorrow. Currently in Invermere BC.Yes, Canada, south and far west, the Okanagan Valley in southern BC interior, near Vernon BC if you have an atlas.
Cheers
Paul
I had bought some JFETs, will check stock when I get home.
(another) Paul
You need two 2sk170 and two 2sj74 for the f5 ... Right ?
/ jesper
Hi Jesper,
Yes, I that is correct.
I'll check out the wiki link...and see if I can get Google to translate it for me.
Paul, have a great time in the Okanagan....it's going to be a scorcher today! I am out working in the shop, cleaning out that one room for my new audio lab. It's about 3/4 done......need to make a dump run.
Cheers
Paul
I am living next door to Germany... I can help you with the translation, if needed...
I will be back home from vecation tomorrow, and have a look, if i can spare some 2sk / 2sj 's
/ Jesper
Hi Jesper,
Thanks! I found the link and google translated it fairly well. Nice site.
Thank you for the offer, but I should be able to find some in Canada/US. Shipping would be pricey from Denmark. I really appreciate the offer though. What I would like to find, ideally, would be a hundred of each so I can match them and have lots for future projects. I also want to build a preamp or two and envision using these as well.
Have a great vacation.
Cheers
Paul
Cheers
Paul
- Catching up on 15 years of PASSt projects...which amp to build first!
