Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Pass Labs This forum is dedicated to Pass Labs discussion. |
AS if i didnt have enought going on, I am starting this thread to play with preamp ideas. Here is the first. It use LTP input in order to try to avoid increasingly scarce reistors. THe y are 369's, but are easily bought in large quanitities. It is based on a mix of the Salas folded RIAA and the Pumpkin. Havent decided to keep final stage common drain or switch to buffer. WE will see.
...Shape the sound , Man! |
#2 |
Is this mine? ;-)
#3 |
Could someone please post a schematic.
Figuring out what it is from a board layout is a bit of a pain. IMHO ![]()
Doug We are all learning...we can all help "You can't stop the signal, Mal. Everything goes somewhere..." |
#4 |
I will post the schematic later. I have a tendency to skip that and go straight for the pcb.
@PKI, You can choose between this and complimentary version. Gonna be one late birthday present ![]()
#5 |
"...skip that..."
Sounds like an idea. Thanks. ![]()
#6 |
Hi Buzz, I know you like playing with circuits, just as a suggestion, why not replace the cascode voltage referance with a TL431, that way you can adjust the voltage with a pot to find the 'sweet spot', you wouldn't need to match the LED's and you could save those JFETs for another project.
You could also replace the LEDs in the output stage with a transistor (or TL431) for an improved current sink, obviously you would then need to match the FETs but I suspect you would do that anyway for minimal differential offset; the LTP current sink would also need the same treatment. ![]() ![]() |
#7 |
All very good ideas. I have the luxury of knowing that these are good operating points as offered in other circuits, but you are right, it would give more freedom.
#8 |
I need some help with folded cascodes. In a typical cascode circuit, the voltage seen by the gate of the cascode device sets the drain voltage of the gain device. In a folded cascode, the cascode device does not set the drain voltage of the gain device, which is now determines by either CCS or Rl. What purpose does the Vref on the cascode serve? What determines the output of the collector of the folded cascode. If not loaded by a resistor or transistor, isnt it functioning as a transimpedance amplifier.
#9 |
Found what I thought was a good reference. It confirmed my suspicions.
The Shunt Cascode Driver | Bartola Valves Will have an updated schemtic soon.
#10 |
Official Court Jester
that one originated from our very DiyA , toob forum
it's already implemented in one veeeery secret (still in evaluation phase ) ZM's shebang however , one need to not confuse it with modulated cascode hints from Pa
my Papa is smarter than your Nelson ! clean ![]() ![]() ![]() |
Thread | Thread Starter | Forum | Replies | Last Post |
Running a tube preamp into a solid state preamp? | Pckid212 | Solid State | 5 | 6th January 2013 10:12 PM |
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | Travis Clarke | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? | Paswa | Instruments and Amps | 1 | 12th March 2008 05:16 PM |
twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
New To Site? | Need Help? |
