F5T with 56V rails?
F5T with 56V rails?
Old 9th July 2013, 06:57 PM   #31
bear is offline bear
expert in tautology
bear's Avatar
F5T with 56V rails?
Buzzforb, he already has the PS iron, so he is trying to use it.
My suggestion was to use choke input...
_-_-
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 9th July 2013, 07:12 PM   #32
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Sorry. missed that part. Of course it can still be done. Duncan Amps PSUD II would be a worthwhile download, i believe, for the PSU and then it is a matter of cascoding the Fe and increasing Rs on the output.
...Shape the sound , Man!
Old 10th July 2013, 07:53 AM   #33
R.I.P.
Originally Posted by buzzforb View Post
.............. apporopriate voltage needed to have the diodes near turn on. .............
I have previously explained that there are different ways to use these diodes for enhanced current ability (= less voltage droop at high output).
You do not NEED "to have the diodes near turn on".
regards Andrew T.
Old 10th July 2013, 06:43 PM   #34
Leify is offline Leify  Sweden
I have just ordered another set of boards so I can build a F5T V3 with 4 pairs of mosfets per channel. Then should the problem be solved. I should have no problem to have +-52V rails and to set the bias for around 30W class A and the remaining in class AB. Then I don't need monster heatsinks as well I guess. My intention is to build monoblocks with 2.2 KVA tr and about 0.5 F per channel. Should be a very nice amp.
Br
Old 10th July 2013, 07:06 PM   #35
AudioSan is offline AudioSan  Norway
you will stil need some semi monster sinks 52V and 1.4A bias = 145W dissipation
but with 2.2KVA transformer, i would build a stereo amp, and save the other transformer for another project.
Old 10th July 2013, 07:33 PM   #36
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
F5T with 56V rails?
Monster transformer, monster heat sinks to cool 16 mosfets (stereo), and monster cap bank? Better put it on casters, so you can move it...
F5T with 56V rails?Hide this!Advertise here!
could the F5C or F5T be run at 40v rails? JZatopa Pass Labs 8 29th November 2012 03:44 AM
Benefits/Drawbacks of Dual rails vs Single Rails buzzforb Pass Labs 2 25th May 2011 01:06 PM
REPLACEMENT FOR ELNA CAPS 8200uF, 56v edusub Parts 3 29th June 2010 11:25 AM
Trying to source 8700uf @ 56V or substitutions CountryScience Parts 2 17th June 2009 08:24 PM
4x Elna Silmic 22000uF 56v Smoothing Capacitors (very rare) Kevinbd Swap Meet 13 23rd March 2006 11:57 AM
