F5T with 56V rails?
F5T with 56V rails?
Old 8th July 2013, 03:13 PM   #21
R.I.P.
then you must prevent blowing up your input stage transistors.
regards Andrew T.
Old 8th July 2013, 04:13 PM   #22
Leify is offline Leify  Sweden
I bought the pcb's here at the store and apperently you can cascode them. So can it handle the +- 52 V rails?
Appreciate all answers,
Br
Old 9th July 2013, 02:31 AM   #23
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
F5T with 56V rails?
F5Turbo Article says Yes. Can you handle the heat?
Old 9th July 2013, 05:45 AM   #24
I have not bought the cases and heatsinks yet so that problem can be solved. However that I wrote in the beginning of this thread is that I want to have a lower bias for aiming to about 30W class A and the remaining in class AB. That could work right?
Old 9th July 2013, 10:10 AM   #25
AudioSan is offline AudioSan  Norway
i say no. you need more then 2 output pairs to handle the heat. 52V*0.9A bias pr device=46.8W dissipation pr device. that is to high.
you can however run it with alot lower bias. like 0.5A pr device (26W dissipation). but it will only give you 16W class A at 8ohm.
Old 9th July 2013, 11:54 AM   #26
R.I.P.
30W of ClassA needs ~1.4A of total bias.
A 2pair output stage with each passing 0.7A is ~35W /device.
That allows upto 2.8A of ClassA output and then it transitions to ClassAB for the higher currents.
regards Andrew T.
Old 9th July 2013, 12:16 PM   #27
0.9A was for the 50W v2. a general answer regarding if one can build a v2 with 52V rails.
v2= 2pair output 50W class A amp.
and one would need to change source resistors so that the diodes dont kick in way too soon. or drop them all together. but then its not a v2 anymore.
Old 9th July 2013, 03:32 PM   #28
Thanks guys,
So if I understand it right it's not possible to have +-52V rails and 30W class A and remaining in class AB what it now will be. What do I need to change specifically to make that happen. Sorry for all these maybe "stupid" questions but I'm new at this and need help.
Br Leif
Old 9th July 2013, 05:52 PM   #29
it is possible. but i would drop the diodes. and cascode the front end.
it will be alot of extra heat doh. 0.7A pr device and 52V rails give you those 30W class A. with a dissipation of just over 140W pr ch(36W pr device). so you will need some monster sinks
Old 9th July 2013, 06:04 PM   #30
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Originally Posted by Leify View Post
Thanks guys,
Br Leif
It is possible but you will have to refigure the source resistor value to drop the apporopriate voltage needed to have the diodes near turn on. The easier way is balanced. You get voltage on the cheap.
...Shape the sound , Man!
F5T with 56V rails?Hide this!Advertise here!
could the F5C or F5T be run at 40v rails? JZatopa Pass Labs 8 29th November 2012 03:44 AM
Benefits/Drawbacks of Dual rails vs Single Rails buzzforb Pass Labs 2 25th May 2011 01:06 PM
REPLACEMENT FOR ELNA CAPS 8200uF, 56v edusub Parts 3 29th June 2010 11:25 AM
Trying to source 8700uf @ 56V or substitutions CountryScience Parts 2 17th June 2009 08:24 PM
4x Elna Silmic 22000uF 56v Smoothing Capacitors (very rare) Kevinbd Swap Meet 13 23rd March 2006 11:57 AM
