BLZS and SOZ problem
Old 8th December 2003, 01:08 AM   #1
Adams_Leo is offline Adams_Leo  China
Default BLZS and SOZ problem
I want to build BLZS preamp and SOZ amp.
1.My CD player no balance output and the SOZ need balance input.so I want modify the BLZS preamp.input unbalance signal but balance output.it can work well,the attach file has modified BLZS SCH.
2.if build 10W SOZ,the 8 Ohm resistance use dale 50W is OK?
Old 8th December 2003, 04:53 AM   #2
mefinnis is offline mefinnis
mefinnis's Avatar
The BLS article tells you that the circuit can be used as an unbalanced-to-balanced converter by simply grounding 1 of the input leads ...... so, yes, this will work.
50W Dale's will be quite sufficient at 10W.
Mark
Old 8th December 2003, 05:55 AM   #3
jh6you is offline jh6you
Account Disabled
In addition, I recommend to replace R3/R4/R5/R6 with constant current sources (CCS), for a reliable set of symmetrical output swings. There are many guidances how to make simple CCS in this forum.
Old 8th December 2003, 02:54 PM   #4
eLarson is offline eLarson  United States
eLarson's Avatar
I used the current source (sink) that NP showed in his A75 front-
end: a zener being fed by a resistor attached to the positive rail,
and filtered with an RC. This establishes a relatively stable
voltage which I used to drive the gate of an IRF510 (two,
actually: each gain MOSFET gets its own in mine.)
It works well, but in my can't-leave-well-enough-alone mania I'm
thinking of cascoding the gain devices.
Erik
Would a woodchuck bother to chuck MDF?
Old 17th December 2003, 01:12 AM   #5
kenbeyond is offline kenbeyond  China
Send a message via MSN to kenbeyond
Default Question
Follow this circuit, unbalance input and balance output, i imitate one and test, but the +output level and -output level is difference, near 0.2V(input 0.5V), is problem? i remember Son of Zen document also same like this. (photo is + - output level addition)
Old 17th December 2003, 09:40 AM   #6
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
Kenbeyond,
this is the normal behaviour if you donīt use current sources. Since the output differential is ok I wouldnīt worry about this.
william
een ooievaar is geen konijn want zijn oren zijn te klein!
BLZS and SOZ problemHide this!Advertise here!
AMP problem nigelwright7557 Solid State 25 26th May 2008 02:47 PM
dac problem kaldirdimgell Digital Source 11 13th December 2007 05:35 PM
WTB: BLZS kit/PCBs vsr123 Swap Meet 2 17th November 2004 04:18 PM
P3a problem Morph Solid State 9 27th February 2003 07:57 PM
